How long after installing would you recommend changing out the fluid.
Red500 Well-Known Member Lifetime Member Supporting Member Aug 20, 2018 5,266 57,058 113 Greeneville, Tn. Ownership 500 Mar 3, 2021 #1 How long after installing would you recommend changing out the fluid.
Admin HondaSxS.com Advertisment trigger Old Ironsides Vendor Lifetime Member Supporting Member Feb 13, 2016 21,209 157,083 113 Bay City, Michigan www.quickshieldutv.com Ownership 500 Mar 3, 2021 #2 Next oil change. Red500 Well-Known Member Lifetime Member Supporting Member Aug 20, 2018 5,266 57,058 113 Greeneville, Tn. Ownership 500 Mar 3, 2021 #3 Ok I changed engine oil the same day I installed the locker so that will work. Thanks. Hondasxs Club Founder Staff member Feb 13, 2013 18,052 63,706 113 Charlotte, NC HondaSxS.com Ownership 1000-5Talon R Mar 3, 2021 #4 Ya. Its not like your motor. No real break in oil is needed. Change it like you usually would. Reactions: Red500
