How long after installing would you recommend changing out the fluid.
Red500 Well-Known Member Lifetime Member Supporting Member Aug 20, 2018 5,183 56,239 113 Greeneville, Tn. Ownership 500 Mar 3, 2021 #1 How long after installing would you recommend changing out the fluid.
trigger Old Ironsides Vendor Lifetime Member Supporting Member Feb 13, 2016 21,012 155,494 113 Bay City, Michigan www.quickshieldutv.com Ownership 500 Mar 3, 2021 #2 Next oil change.
Red500 Well-Known Member Lifetime Member Supporting Member Aug 20, 2018 5,183 56,239 113 Greeneville, Tn. Ownership 500 Mar 3, 2021 #3 Ok I changed engine oil the same day I installed the locker so that will work. Thanks.
Hondasxs Club Founder Staff member Lifetime Member Supporting Member Feb 13, 2013 18,020 63,406 113 Charlotte, NC HondaSxS.com Ownership 1000-5Talon R Mar 3, 2021 #4 Ya. Its not like your motor. No real break in oil is needed. Change it like you usually would. Reactions: Red500
