P1000 Control arm torquing procedure
lukpy8810
lukpy8810
91
203
Minnesota
So I have a new to me p1000-5 (2018) and I just started replacing the front wheel bearings (they were pretty bad). I removed the lower control arm bolts from the frame to make it a bit easier to get the axel out and remove the ball joints. When reinstalling the bolts for the control arm to the frame should I do final torque at "ride height" or "full droop" getting conflicting results with an online search
Reactions: TxDoc and JenElio
ODAMO
ODAMO
1,177
3,206
Ohio
Ride height. Otherwise the bonded rubber bushings will give a harsh ride and not last very long.
Reactions: TxDoc and Smitty335
JenElio
JenElio
64,974
608,268
Loxahatchee, florida
Welcome to the club from South Florida
Yes, do a final torque down at ride height, roll the buggy back n forth a few times then tighten everything one last time.....(what I did anywheyz)
Post up some pics of your buggy 👍
Reactions: TxDoc and ODAMO
ODAMO
ODAMO
1,177
3,206
Ohio
Yes, good point, rolling the vehicle back and forth a few feet is necessary before torqueing the a arm bolts because with independent suspensions the tires move inward when lifted off the ground and will not fully settle because of side loading.
lukpy8810
lukpy8810
91
203
Minnesota
Awesome thanks guys appreciate the help
Red500
Red500
5,309
57,535
Greeneville, Tn.
Welcome to the club from East Tennessee.
Looks like I did it wrong on mine and will have to do it again. Thanks for asking that question.
lukpy8810
lukpy8810
91
203
Minnesota
Thanks! Seems like a good place to be a part of with the new purchase! Yeah I would like to avoid having to take things apart more than I have to do I figured the brain trust on here would know the answers I don't!
Reactions: Red500 and JenElio
ODAMO
ODAMO
1,177
3,206
Ohio
These torque values are for the 22 and 23 models. They have 12mm bolts top and bottom, 4 in all.
Prior models have a single 10mm top bolt - I'm not sure of the value for it, perhaps someone else can chime in on that.
lukpy8810
lukpy8810
91
203
Minnesota
I have a 2018 maybe that's why I'm seeing 47 for the lower a arm bolts
ODAMO
ODAMO
1,177
3,206
Ohio
my book shows 74 for all a arm bolts upper and lower frt/rr.
Maybe @HondaTech can shed some light on this
lukpy8810
lukpy8810
91
203
Minnesota
I mean I'm fine with doing .it to 74 just want to get it right lol
ODAMO
ODAMO
1,177
3,206
Ohio
I agree. Thats why I denoted that the numbers I listed are from the 2022 model year service book. If they are different for a 2018 someone with more knowledge on that model can verify for you.
lukpy8810
lukpy8810
91
203
Minnesota
Thread 'Torque Values - A-arms, Ball joints , Shocks' P1000 - Torque Values - A-arms, Ball joints , Shocks
This is where I was getting my 47 from I have the same.machine (yellow and all) looks like it was from @HondaTech
Reactions: TripleB
Rayger143
Rayger143
2,741
23,735
Winfield, BC Canada
If you upgrade your membership you will have access to the service manual under the resources tab up top. Here is a screenshot of what you are looking for.
1697083643713
Reactions: TripleB and ODAMO
ODAMO
ODAMO
1,177
3,206
Ohio
I would go with the numbers you found in that thread because there may be some other differences between the 2018 and 2022 that I'm not aware of. You might get some additional input tomorrow when the working stiffs awaken...LOL
