P1000 DIY rear expedition rack & build P1000M3
L
LCCOUTDOORS
6
55
Oregon
New to the group and my first post. I have read a ton in so many categories and have found the information posted to be extremely valuable!
Here are a few pictures of my rack build. I will run it for 8-10 months and make any additional fabrication changes I need to. This fall I will have it sandblasted and powder coated. Don't mind the dirty shop.
It's the first one...... Mistakes were made :)
IMG 2938
2018 PK1000-3 -LE
Purchased new 11/2019
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
2018 PK1000-3 -LE
Purchased new 11/2020
Dang I need one of those for duck hunting. Looks good.
ehart814
ehart814
1,654
3,643
NWPA
I like it. Would be cool to adapt that to replace the rear section of the cage on a 5 seater so It would act as protection for the rear passengers but also add overhead storage
L
LCCOUTDOORS
6
55
Oregon
I was looking hard at a 5 seater (Prior to purchasing the 3) and thought at the time if I got one I would modify a standard 3 seater roof and add a custom cargo basket to the rear roll bar. I ended up the 3 as the I wanted more bed space and it's rare I need to deal with more than 2 buddies. No one likes me that much :) I will say though that the honda bed rails are not as rigid as I would have liked. After purchase, I decided instead of resting the rack on the bed rails I would make it look that way 1/16 inch gap between the bed rail and rack with a bicycle intertube cushion/wear but actually have the weight of the rack and the attaching point in the bed itself. Time will tell if that was a good idea or not :/
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
JenElio
JenElio
65,049
608,847
Loxahatchee, florida
2018 PK1000-3 -LE
Welcome to the club! Thats a good looking rig!!
Isaiah
Isaiah
2,191
6,964
Altamont TN
2018 PK1000-3 -LE
That looks really good;)
L
LCCOUTDOORS
6
55
Oregon
Update-
Installed the factory winch, wire harness for the LED lights on the rack and tighten the rear springs. -Winch took about 4 hours.
-Rear springs took about an hour and a half. Removed tire and springs. I would have spent even more hours on it if @Cuoutdoors wouldn't have spent some time via email supporting though it. -Big Thank You-
-Wire harness was a little over an hour also. Mounted the two relays under the hood. I have ordered a 4 gang rocker panel with voltage gauge and 2 usb. This will be attached to a aluminum plate I’m making that’ll replace all the safety feature puplic announcement plaque. Got a project for next weekend.E07FFF5F FA41 4674 8B29 981B6F49F88B7A1176D6 66A1 45C8 BC88 0425D6C59185F06E7E32 6D3C 41F8 B27E 012701DF265D10299B0D D1B4 4723 A866 2DFFBA14991C5D75F413 D534 47F6 A58F 6FFA92A4FC8D
Update-
-Wire harness was a little over an hour also. Mounted the two relays under the hood. I have ordered a 4 gang rocker panel with voltage gauge and 2 usb. This will be attached to a aluminum plate I’m making that’ll replace all the safety feature puplic announcement plaque. Got a project for next weekend.View attachment 181795View attachment 181796View attachment 181797View attachment 181798View attachment 181799
He’s a good dude... you’d never know he’s gay by just talking to him!
Jsb1234
14
12
Alabama
That rack looks awesome , how long did it take you to build it? Older thread I know but I’ve been looking for one for my 3 seater
L
LCCOUTDOORS
6
55
Oregon
Thank you! I’d say way to much time hahah (prob 30 hours) but it’s been worth it. Lots of trial and error. Prob more error. I ended up adding a bunch more to it. Addition water tank and spare tire tail gate. I’ll get some pictures added.
Reactions: Lady01 and Lochsa88
Similar threads
