P1000 Drafty
Jasperlewis2810
Jasperlewis2810
Mississippi
I have roof and back panel with sliding rear glass. The superatv front windshield is awesome in the summer with the flip up capability, however this time of the year the gap between the top of windshield and roof produces a very unwanted draft. Any of y’all got a quick east fix for this? I’ve thought about pool noodle but not sure how well that will work or where to buy one this time of year.
8ED83D66 FDE7 4637 8A62 4F2D4B1FDFA6
5,096
22,919
Closed cell pipe insulation from any hardware store. Closed cell can't fill up with water/snow/ice.
Vikes79
Vikes79
SKOL!
11,102
107,765
South Dakota
  2. Talon X4 LV
4” square foam insulation works too.
if you jam some between the bed and the soft mid panel that helps with dust as well.
use some truck tailgate seal on the bottoms of your half doors also helps as well.
The dash is the hardest. I have a shift plate from @Montana which helps. I just jam a rag in the steering column for that one.
your results may vary.
Vikes79
Vikes79
SKOL!
11,102
107,765
South Dakota
  2. Talon X4 LV
Here is how mine is done on my soft top. Front window is similar.
The seals on my doors have been on since 2018. I just used two sets of generic tailgate seal kits off eBay. Note that you should lay the hinge side differently. You want the seal to wipe or pinch without rolling. Does make the floor warmer in the summer…
