P500 Dust Snorkel Mod.
bowhunterbob
bowhunterbob
Lancaster County Pennsylvania
Has anyone done a dust snorkel mod to a P520 or any other dust reducing mods? I am looking to add something to mine if anyone has pics or videos. When I was riding in northern Idaho, a guy had one on his P500 because the trails out there are incredibly dusty, which is where I got the idea. If there is a thread that I missed somewhere, copy me a link please.
Reactions: Mudder
158,637
A dust snorkel? Like pulling air from inside the cab? I would think that would be the only difference as opposed to the typical snorkel pulling air from the back of the machine. Other than that it's about how many layers of filtering you have in place. I run a K&N oiled filter with a pre-charger on it and then panty hose over the snorkel tips. Pulling air from inside the cab would probably be loud.
107,312
just trying to keep dust down any way possible.
BLAHAHAHAHA u have a sxs right?
Full enclosure about as close as ur gonna get.
What @trigger has keeps dust out of the engines air filter if that's what ur asking? Sounds like ur asking for a filter like a cars cabin filter for the cab? If that's the case, good luck with that.
158,637
I have some pics I can load later, on my phone at work right now. Simple 2" pvc and a 2" Fernco and you're up and running. How you route and terminate is up to you. The only thing it's doing is moving the point of intake higher. Better for water intrusion for sure, jury is out for dust intake though. 🤷‍♂️
107,312
Thanks, I will take your pics later for sure and anyone else that wants to show snorkel setup so I can copy it.
If u do a search up top, there is an old thread on how to do this. Also in there is my old P5 build “Remi’s Bumblebee build” that has details like Triggs on how I did mine.
Also, dont forget when responding to someones post to hit the “reply” at the bottom of there post then finish your response. Otherwise we wont get a message that u responded. Just happend to be scrolling through and stopped to check it out this time
HiFive
HiFive
624
2,535
West Central Fl.
Just snorkel and add pantyhose.
1020201125a
bowhunterbob
bowhunterbob
I’ll check all of that out, thank you!
Got it on the reply miscue, thanks.
158,637
Honda Bob's shows the Fernco's, just the brand name of rubber couplings. Don't have a detailed picture where I cut my intake tube or anything but like I said, how you route and terminate is kind of up to you. The best advice I can give you is don't reduce the size of the intake tube. Some guys reduce it to 1 1/2", probably cheaper and easier to work with but it's going to restrict the amount of airflow and that's not wise. Here's what I have...
SnorkelSnorkel Intakes
bowhunterbob
bowhunterbob
Reactions: Pakker and Mudder
