![makac132](/data/avatars/m/9/9474.jpg?1575964297)
Hi guys, did any of you installing winch bothered to protect it with a breaker and if yes what size? Thanx for taking the time to answer.
Some definitely have. It depends on your winches draw so you may want to post your make/mode/size at least. The spec sheet for the electrical load would be even more helpful if you have it. Several guys around that can help point in the right direction at that point.Hi guys, did any of you installing winch bothered to protect it with a breaker and if yes what size? Thanx for taking the time to answer.
Some winches come with 50 amp breakers, and that is way too small for a guy who is in trouble and trying to haul his machine out of a mud hole. I have no cct bkr on mine, and it makes me nervous, but I couldn't find a 300 or 400 amp breaker. Then I thought, if a short circuit is drawing 3 or 400 amps, she's going to burn anyway. So, if you have a useful winch, get fire insurance.I have a 300 amp circuit breaker on mine. Some would say that's too high but a winch can draw that much power when being worked and if you're in a pinch and that breaker keeps tripping due to being too low, I'd rather not have one at all.![]()
Thank you guys for the replies. I installed 60” Warn plow and Viper Max 3500 with synthetic rope on my then new P5 two Christmases ago in a hurry. Basically hotwired everything including the control, so it’s ON all the time. Now I’m adding LED lights in front and back and I think it’s a good time to play it safe and add second battery with insulator (True Ame) and proper protection for the winch and rest of the AUX side as well. The Viper came with 5 AWG wires so I’ll put 4 AWG on it and was thinking of 300A breaker but wasn’t really sure. That’s probably an overkill for plowing but when going up the mountain and got stuck in snow then it’s a different story. I can’t find any spec sheet for the Viper’s load characteristics so there it is.
Probably buy a lithium ion jump pack for the same price as that isolator.
Personally I would only use the Jump pack to start an engine, then give some run time before winching. Thinking my CB is 185 amps, and if the winch stalled or breaker tripped, time to break out the snatch block or a different line of pull. IMHO.Kind of wondering how far the jump pack is going to drag me threw the mud after I kill the battery.
Got the feeling it's going to pull great for a few seconds (about as long as it takes to start a Duramax) then die.
I'll report back after I do it (probably be in the shots from the trail section as I will still be stuck in the mud)
So many threads pop up on a search of Dual Batteries (all forums). Looks like a popular thing. Remember some technical discussion on issues with non-matched batteries, guess an isolator eliminates those issues?
