P500 Enclosed trailer width
Mudder
Mudder
NTC Ambassador of Walls
11,395
85,085
Anyone have a 7ft wide enclosed trailer with the P500? Enough room to exit the sxs ok inside? Debating on a 7x16 versus 8 ft wide from comments on excessive wind drag. Likely extra height due to roof and taller tires.
HUCK
HUCK
1,047
2,315
ARIZONA
I have a 12x7 Hallmark trailer . Width isnt the issue , p5 is too tall to go in . My Rzr will only go in if I collapse the rear springs/shocks .
Reactions: Mudder
Rustell
My toyhauler is 78" wide between the wheel wells . The door height is also 78". I don't have to much trouble getting in or out. I usually load it with the drivers door open. Ztrailer1Toyhauler
Reactions: Mudder
lee
lee
Village Idiot
2,357
13,307
Springfield Ohio
I've used the open drivers door trick too.
I strap the door open with a small bungee strap so it stays open.
Keep having visions of backing it out, forgetting about the door and ripping it off.
Hey, if it wasn't for bad luck I wouldn't have any luck at all.
DaddyDubbs
DaddyDubbs
14,008
130,954
I have a 6 x 12 enclosed Lark trailer, Inside dimensions are 11'-4" L (13'-2" to V-nose) x 5'-8" W x 6'-6" H - Door is 5'-3" W x 6'-0-1/2" H. My 2017 fits fine, open trailer side access door, drive in forward, set brake, exit through passenger side. Tie down on 4 corners and your done. My trailer is single axle, and my VW Touareg pulls it just fine at 75 MPH.
Reactions: lee and Mudder
Mudder
Mudder
11,395
85,085
After looking at 7x16 and 8.5x20, about ready to order 8x18, 7 ft tall with beaver tail entry, 80 inch tall door opening. Around $5k with upgraded materials. Spartan trailer. Any insight? P500 and Rancher atv only had 6 inches in length to spare in 16 footer.
Reactions: trigger
DaddyDubbs
DaddyDubbs
14,008
130,954
Sounds like the 8 x 18 will fit your needs nicely. While the 7 x 16 would work, a 6 inch cushion isn't a lot, and you loose other storage space, I keep a trailer spare and jack kit in the trailer, plus room for cooler, etc.
