P500 Securing my P500 on the trailer for transport
156,461
If you know what you are going to haul and where the tie down points need to be then why use etrack? Just install 4 heavy duty D rings with proper bolt through to the trailer frame. No screws...use bolts.
To allow for options. I don't have E track installed in mine but can see the beauty of it for hauling options. Set mine up specifically for the machine but have hauled several other things over the yrs and wish I'd installed E track. To accommodate the same amount of pick points, you'd have D rings installed all over the place.
5,026
22,455
Yep, sometimes I'm carrying extra 'stuff', sometimes I'm not - insert overposted pic of fuel in front of the buggy vs empty for day rides, a 9" difference in position because of RV tongue weight limitations (so I can't just ignore the difference).
mpilihp
109
204
Maine
I use my trailer to haul multiple things so I use the D rings provided on the trailer. I use large 2 inch ratchet straps and I attach on the a-arms by the wheels so there is little to no flex and loosing of the straps as the rig bounces. I also have a couple extra straps so in total its held by 6 straps, one at each wheel and then one in the front and one in the back. Those two could loosen as it bounces but they are the extra safety ones and Ive never had one fall off/come disconnected.
JP51
21
87
Texas
Get 4 or get a lawyer, your choice.
Safety should not be done halfway. My trailer affords a great way to secure the front end now. I only need the nets for the rear tires.
Who Said I wasn't securing all 4 wheels? Planning was for 2 of these bonnets for the rear and a different method for the front wheels.
JP51
21
87
Texas
Now let's talk about securing the rails to the 2x6 deck.
E-trailer sells a "backing plate", but a tad pricey at $10/each. Why wouldn't 1/4" bolts (same size as the rail mounting holes) with 1/8" thick fender washers placed at every mounting hole work just as well?
Bandman
Bandman
128
457
Hayden Lake, ID
Hillbilly Brake is a gizmo that locks your brake pedal down. If you have a manual parking brake, you don’t need the HB. P1000 don’t come with a parking brake 🤔
I use 4 wheel nets. If you wreck, you want the machine to stay on the trailer no matter what. You DO NOT want it in the front seat with you. Or in somebody else’s front seat.
Check out Ratchet Straps | Tie Down Straps | Custom Made Ratchet Straps
You can have them custom make straps exactly to fit your needs. And the price isn't horrible.
Great looking equipment but $40 to ship $103 worth of product? I’ll keep looking.
Dj2833
12
Suffolk County, NY
My trailer is 5'6" x 10" with 2x6 flooring. Big enough. I hauled "Scooter" to my deer lease and had no real issues.
But I was only able to put a ratchet strap across the "winch area" up front. Where should I strap it down in back? Once I get a hitch, I suppose that would be a good thing to tie down to, but I read it's only good for 100# of tounge weight.
I put the manual brake on, but the P500 seemed to rock front to back a little more than I'd like. I had the manual parking brake on:
- Supposed to you leave it in "drive" or put it in "neutral"?
- Do you put wheel chocks on all 4-tires?
Thougts appreciated.
I have 4 of these retractable straps bolted directly to my trailer. I use motorcycle tie down loops around frame and clasp the strap on. It’s that easy. As fast as you can unclasp that hook is all it takes to unload. Life is so much better 😀
4C37D8DE 2182 4052 AD8A 63217FB69262 3CB8C078 5F9C 4A8A B910 E1FDBBB877F6
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,762
183,062
Grand Junction, CO
Rear
1663270870212
Front
1663270966686
Rdrcr
458
2,519
WA
I've been using US Ratchet Straps hold-downs;
They're strong and easy to use.
Mike
Reactions: Biteme
