P500 Securing my P500 on the trailer for transport
JayPo
JayPo
Somewhat Well-Known Member
10,907
105,930
Tennessee
measured my tires. Center to center on the front tires is 41 1/2". The back is 40 1/2". So a single long rail on each side could not centered on both front and back tires. Might that be problematic? And those long rails are pricey!
Mount the e-track so that its 41" center to center and you'll be fine.
hallic
hallic
320
1,795
Central MN
Like @JayPo said, mount the center of the rail at 41". Or, if you plan on getting bigger tires, go a bit wider apart. The straps themselves are about 2" wide and my front tires are 9" wide, backs are 11", so there's plenty of space for the strap to grab tire tread. They don't have to be perfectly centered, just close enough. That's the other benefit of doing all 4 tires, once it's strapped down it's not moving.
But yeah, went up in price a bit. I got lucky and caught a good sale a while ago, and got 20 feet of e-track, 4 straps, and a bunch of other e-track hookups for well under $100. Unfortunately, it's the "vertical" style, and not "horizontal" style, so It has less places to hook into, but still works.
If you are going this route, look for an e-track kit, with 4x 5' rails. Usually cheaper than trying to get 2 long ones. Quick Amazon search looks like you can still get a 4 pack of 5' rails for about $100 or so.
JMynes
JMynes
541
3,227
Augusta, Maine
E-track is awesome stuff. I’ve had it in two trailers. But not my current one.
I have a dump trailer and dirt would fill the E-track, so I have loops front and rear of each wheel for the wheel nets.
If it were any other kind of trailer I would use E-track.
208,028
I have a 18 footer that I use for everything, fire wood, mulch, dirt, furniture, our S X S, Zero Turn, 4 wheeler and tractor, all are different widths, no E track for me.:confused: I had 6,000 LBS D rings welded to my trailer in 6 different places to accommodate my different requirements, I tie off my S X S to the closest center point on the A arms, works great, survived a 50 mph head on.
HiFive
HiFive
625
2,545
West Central Fl.
What trigger said use holes in frame to ratchet down.
1020201125 1009201456
JMynes
JMynes
541
3,227
Augusta, Maine
Straps should pull the machine down to the trailer deck, not up over a railing.
And get yourself some 2” straps. If you wreck, those 1” straps are going to snap like dental floss and the SxS is going to be in the front seat with you.
You’re not just carrying the SxS on a trailer, you have to secure it to the trailer so it stays there in a worst case scenario.
159,126
My only concern with the E Track is securing the rails to the aluminum trailer deck. I plan to use 1/2 inch sheet metal screws. I assume LocTite doesn't do much to help with that application.
I would bolt through and consider plates on the underside.
JMynes
JMynes
541
3,227
Augusta, Maine
I would use machine screws. 1/4-20 if they fit through the E-track holes. Fender washers under the deck, and nylock nuts. Backing plates at each end of each E-track strip, and wherever each tie down fixture is installed.
Overkill? Most every day, yes, it’s overkill. But one day it could be the best decision you made about your trailer.
HiFive
HiFive
625
2,545
West Central Fl.
Thanks for the info.
