P700 Engine to rear transfer case drive shaft
BigMac
BigMac
48
92
Anyone getting rear universal and drive shaft parts 700 waiting in shop?
41,819
Been on backorder for a while. If your yokes are ok you can get a u-joint from quadboss (I believe).
@BobRack seems to have come across some and he had it up for sale on fb.
Reactions: BobRack
BigMac
BigMac
48
92
I believe he order the yokes too. I saw some wear that joint may have been causing scraping on yokes. That creating the chirping noise that got us looking.
I will check tomorrow with shop and have them tell me if order more than the joint.
Thank you
Reactions: DG Rider
41,819
Thank you
I'm pretty sure you can ONLY get the whole shebang from Honda. The individual u joint is a aftermarket solution.
BigMac
BigMac
48
92
Mechanic found the part at another shop and it’s shipping next week. Honda did not have a ready shipping date.
I really need it to check calves in fall so I have another P700 on waiting list. Been wet here so calves not getting attention they need when in trouble. Have to use tractor as truck will get stuck.
I figure Honda if should get a good resale if I keep the standby clean.
2006 has had near daily use year round. Also replacing all cv joints front and back, brakes were worn out too on my green one.
Reactions: DG Rider
