P700 Fabric Door Insulation / Operation Questions
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
Hey guy I just purchased the Honda Fabric doors for my 2018 700-4. I see a warning on them not to have them attached during transport. Does anyone have any advice on the removal of the doors before transport? Should you remove the doors? Also does anyone have pictures or video of the installation process? Thanks!!!
Reactions: BHarris8753
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
Well I drove with mine attached at 65 for about 150 miles on the way home from a moose hunt. Seemed to do fine but my concern would be the prolonged wear. I also have hard top and windshield so that may have helped as well.
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
Picture of the moose we took out!!
361C0C3E 0FC6 4AF9 940A DF17EA5FF89F
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
They attach by putting the frame in 2 slots you mount on the door and Velcro them in. Then there is a blot that threads through the frame into the top of the door. Literally take about 30 seconds to put them on or take them off. On the way down to hunting camp I had removed them and payed them inside the machine and ratchet strapped them down.
BHarris8753
BHarris8753
78
86
Robbins, NC
Sounds easy enough. So when you remove them what is left on the main door for the summer months?
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
I have attached photos. The first is the inside of the door where you see the “clips” You slide the door into. Then you Velcro them in. The second is the bolt that you thread into the door.
BHarris8753
BHarris8753
78
86
Robbins, NC
right on man. thank you for the pics, ive been looking everywhere trying to find pics of the installed hardware to see how easy/hard they would be to remove.
Alaskapioneer
Alaskapioneer
7
Fairbanks, Alaska
No problem. They are interesting to install to say the least. I did the passenger side first and it is a little off. Really read the instructions good and double check your measurements before you drill. You will need two people for the measurements.
BHarris8753
BHarris8753
78
86
Robbins, NC
Thank you for the heads up on the measuments, ill make sure i follow the instructions to the letter.
