Forum testing tonight at midnight 12-1-18 Expect errors.
63,988
Tonight at Midnight EST expect some errors as the forum is sitll not 100%.
We still have an issue where if you use HTTP://hondasxs dot com vs HTTPS://hondasxs dot com that you get logged out over and over.
So if you just go to hondasxs.com you will be sent to http. Click anywhere and you will go to https. Login here with no problems.
I actually have not tried to fix this because it's better to be 94% online then 100% offline.
SOLUTION.
The solution is to direct all http to https through a .htaccess rewrite. But when activated it throws it into an infinite loop that I can't seem to stop. Could be Cloudflare compatibility issue.
If you know what I'm talking about post below with ideas as to what to check.
Ok. 2 hours and counting.
Thanks.
Reactions: sharp and BWAF
nbomar
nbomar
4,416
17,854
Springdale, AR
SOLUTION.
Thanks.
Disappointing Richard. Get it together!
Simple solution... get all the guys using https these..
998EB372 A517 46A7 B319 D6C8E399D7E5
