P700 Frame End Plugs
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Regarding the open frame tube ends:
Some folks have bought the square plugs to close the frame tubes. They say it keeps water out, and prevents rust.
Some folks say that you need to leave the frame tubes open so water and moisture can escape out of the open ends, and allow air to dry the inside...again to prevent rust.
Any thoughts...
Reactions: Mudwing
156,863
Any thoughts...
They're going to rust either way but putting the plugs in looks better and keeps some mud out. My 2c.
lee
lee
Village Idiot
2,336
13,101
Springfield Ohio
Water will get past the plugs, so it will rust.
I like the idea of cleaning the frame tubes with the pressure washer, then hit the inside with an oil like 'Fluid film'.
Your mileage may vary
Reactions: bpike207
swsebek
swsebek
2,854
5,828
pa
I agree 100 percent
41,820
I think it's better to leave them open. In fact, all of my caps eventually got spread around central AZ (by accident).
Take 1 of the engine skid bolts out on occasion on the rear crossmember as well. Always had a lot of water come out of the hole whenever i removed one.
swsebek
swsebek
2,854
5,828
pa
IMG 1939
And make sure you check the front ones especially.Stuff starts growing in there:eek:
