P700m2 P 700 Frame badly rusted.
Moosehunter
Newfoundland
My frame is badly rusted . Has anyone stripped there 700 to the frame to restore it? How long and hard a job it is? Paint on frame is really peeling bad as well.
208,013
First thing I would do is get a BIG bottle of patience pills, it will be a project!
Reactions: Mudwing
jwfirebird
jwfirebird
927
1,446
western ny
you could try rust converter spray, some ive used work on light surface stuff. places that hit are just going to continue rusting. normally get aluminum plates and a arm protection for that reason aside from sticks doesnt look that bad after being scraped up
Reactions: Mudwing
208,013
Yep, I didn't think to ask where it's rusted, I was thinking about a frame off paint job, DUGH! If it's just the A arms, would look into some accessory A arms and skip the paint job! I bought Super ATV arched A arms for $ 550.00, love them!
Moosehunter
Newfoundland
It’s the complete frame , even on the bars above my head. I believe that it was a faulty paint job to be so bad after only 4 yrs.
208,013
WOW! Have you sent Honda pictures? And talked to you dealer?
Reactions: Farmer
Moosehunter
Newfoundland
No, it was bought used . Got a great price because of the rust so i’m Trying to find out the best way to fix the problem.
Appreciate the help
jwfirebird
jwfirebird
927
1,446
western ny
i had alot of old cars and the salt here you always have problems here, places you see want to look nice, probably get some wire wheels for a drill or grinder. they make fine ones rough would mess it up. put gloss rustoluem on that stuff. the other would just put some automotive rust converter on, some of the better stuff will seal it so it stops. did alot of stuff on my old rhino with walmart truck bed liner flat black, floor, rad sides and front bash plate were all made from metal and coated with that.
20180120 094122
208,013
Appreciate the help
Sounds like a winter pro
Wonder where it was stored and maybe what chemicals?
Farmer
Farmer
2,851
16,389
Southern MO
1st let's be clear.....Powder coat is far from paint in my book. Hell, I'd go as far as saying it's one of the biggest scams pushed on the public in my lifetime.
2nd, Is it surface rust or flaking metal with holes? Got pictures? If you have soft holes and flaking chips I'd be looking for new or donor parts.
3rd, I'm a big fan of OSPHO for surface rust. Sand, grind, blast or whatever it takes to get that plasticky powder crap off. OSPHO it. Then, use a good traditional primer and PAINT to fix her up.
Reactions: Mudwing
Moosehunter
Newfoundland
Thank you , I was thinking along the same lines, rust converter, and then rustoluem. Gonna be a lot of work. That’s why I asked if anyone has ever stripped down to the frame.
What is OSPHO ?
Farmer
Farmer
2,851
16,389
Southern MO
What is OSPHO ?
https://www.amazon.com/SKYBRYTE-Skyco-Ospho-Surface-Prep/dp/B000C02B3W?tag=sxsweb24-20
An old farmer turned me onto it a long time ago. He said they used to use it in the navy.
I've also had good results with EvapoRust for small parts and tools. It suggests using soaked rags draped or wrapped for larger areas.
https://www.amazon.com/dp/B00M0TLQ66/?tag=sxsweb24-20
Reactions: Mudwing
SXS12345
louisiana
I had a truck one time that had a rusty frame mostly cosmetic surface rust no damage. I cleaned the frame, scrubbed down with a solvent and a brush. Sprayed with some rattle can frame spray and it held up really well. Looked great to.
I really don’t understand on ATVs/UTVs why they don’t just rhino line the frames and exterior metal from the factory.
Moosehunter
Newfoundland
I agree, paint is such a waste
jwfirebird
jwfirebird
927
1,446
western ny
all businesses are all about cost savings, they use a too short screw if it saves 5 cents on all the machines they certainly aren't going to spend hundreds on anything. probably why it rusts in the first place cheap thin paint
Reactions: Mudwing
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
In a past life, I designed chainsaws.
Every Engineer was tasked with finding costs savings.
I tweaked the design and the cost of screws went from $0.009 to $0.007. 2 tenths of a penny.
We used 14 million/yr of those screws. That's close to $30,000.
I got accolades for making it more crappy.
I'm just saying, that's how desperate they are.
SXS12345
louisiana
I've always admired engineers, not something i could ever do. But i agree my company i work for spends a million dollars to save 3 so it does make sense,its all about the money.
Reactions: Mudwing
Moosehunter
Newfoundland
I’d rather pay the extra and also for stainless steel screws. Rusted screws look like crap
Reactions: Farmer
