P1000m5 Front bumper shackle mount
smoothie25
smoothie25
17
64
Illinois
I want to add an anchor point (or 2) to the front bumper to attach a shackle for towing, recovery and strapping to the trailer.
I’ve got it narrowed down to three options.
1 Add tow hooks
I like the simplicity of the hooks. Nothin fancy and cheap.
25b2e13e47d0d1b358f6ceb183705d2f
2 Bolt on shackle mounts
I got a quote from a local welding shop to get a set of shackle mounts powder coated and like this look the best. I could probably spray paint them but not sure how long it would last. I’ve read some reviews saying the bumper where these attach is prone to bending under heavy load. These will be used to pull the SxS out of snow drifts/mud/etc and assist getting trucks unstuck so it needs to be solid.
F6c3d52dd2b194f608a9fc9a351731d3
3 Bolt on a front receiver hitch and add a shackle receiver
This appears to be the foolproof route and possibly the most durable.
7af1c8f0c8a402f4e5b8aad2590b46cf
Sorry if I poached a pic of your ride. Let me know what experience you have with each. Any input is welcome. Thanks!
105,313
Have had both, the cheap large D rings on a stock bumper and currently the removable clevis type in your middle pic on an LE bumper that is essentially the same as the base stock bumper with ears on it. To be honest with you, anything on those bumpers are 90% for looks and very lite and I mean very Lite pulling. They can and will rip out of that bumper like a stump from a heavy winch. Mine are bolted and welded on the inside. Ive used them to Pull very lite things, like a dead snowmobile in neutral off a trailer and thats max. You can see both in my build.
JMynes
JMynes
542
3,230
Augusta, Maine
You need to be pulling on the frame. The bumper is attached to the frame with 4 little bolts, any force is going to bend and fold stuff.
At first glance it looks like those lower hooks are on the frame. I’d go with that, mounted with a couple of 3/8” bolts.
Pulling from a low point will tend to lift the front end out of the mud. Pulling from up high will compress the suspension and push the wheels deeper in the mud.
56,720
I've winched off mine to recover myself snatch-blocked as well as others more times than I can count. Been on there for almost 3 years with no issue. I've got a piece of 1/8" thick steel on the back side where the D-Rings mount.
The day I installed them
1670258578527
1670258837661
Today
1670258910072
Bow4life
Bow4life
108
465
Minnesota
I have 2 shackles mounted to my front bumper with 1/8" steel backing plates and grade 8 hardware. Have been good so far but I havent used them to winch myself out yet. They are powder coated and seem to be holding up well.
20200929 223241 20200927 201303 20200927 201256
NorthernJoe
NorthernJoe
325
1,248
Northern Ontario
I did a version similar to post #7, but instead of a backing plate, I used some 2x2x3/16 angle iron bolted to the bumper frame mount. Then you can add shackles or just a simple eye bolt Good luck with whichever method you use
319,736
I cut holes in face bar and slide square bar through to bumper mount and welded both to that and face. Torn that bumper up over the years and it’s now been on multiple Pioneers but that is still holding up
C28BF73A 2F43 4374 9345 DAC84FFC0EAC
380D22E0 1D9B 49A2 905F 2E2D589D7536
3D92130E 372D 4EEC 8EB7 8CAAE3321D22
4F231544 115A 4F1A 8706 A5109CF5E58F
EECF9BB2 89A0 4F23 87A8 477F188138CA
RedorDead
84
475
53
USA
Darn it, guys! I am trying to shorten my to-do list. Not lengthen it.
This isn’t helping. ;)
(adds another mod to the list)
Reactions: Rayger143
someguy1313
someguy1313
170
372
SouthEast
I went with the front receiver hitch as I was worried about the bumper strength. Bent my bumper first time out getting pulled out of some mud.
View attachment 365320 View attachment 365321
Hi. please clarify: Do you mean that happened after you installed the front rec. hitch? i'm trying to understand what happened and why. I have the rec. hitch and have self rescued many times with no issues, but definitely want to understand your experience.
thanks!
Reactions: NewHere2
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
1 Add tow hooks
I have the receiver hitch type. I have used to move my trailer around the yard. I havent used it for any HD purposes
Reactions: NewHere2
Jankyeye
Jankyeye
524
2,262
Tampa, Fl.
thanks!
Happened before the hitch and winch were installed.
C493CD27 204B 4EE6 9B31 DFE77ED8447D
