P1000 Front end loose? Sloppy steering?
Alaska350
Alaska350
96
233
Anchorage, AK
You may have to remove both tie rods and turn the rack so it sticks out the driver side. This will give more access on the passenger side.
I don’t think there is a bushing in the driver side.
Is it do-able without removing both sides?
105,176
Joey hasnt posted on this thread in a long time. Your best to send him a PM and he may get an email to answer you directly.
Reactions: CID
P1K5Dave
P1K5Dave
2,162
8,086
Petoskey, MI
I don't believe I had to remove both sides. You will want to check your left inner end while your in there though.
P1K5Dave
P1K5Dave
2,162
8,086
Petoskey, MI
Driver side inner tie rod end joint. Just check to see if it's solid while you're at it.
Reactions: Alaska350
