P500 front shock package
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
they flex much better then stock
Screenshot 20170116 082202
chrisC
chrisC
138
259
Newfoundland, Canada
the trail has more travel but i think the compression and rebound feel about equal
I agree! It's very comparable. On most terrain they are VERY close.
Longer travel will have the advantage ,and that's not as easy to change on our 500's
I've been looking at those Outkast long arched a arms with 3" lift. Pretty cool....But widens the machine a lot.I don't want to deal with more width and more mud though. Lol.
Great that you can offer the changeover service Jak !
Makes the front shocks a bolt on job for those without welding access!
Sent from my SM-N910W8 using Tapatalk
chrisC
chrisC
138
259
I haven't been running a swaybar on mine.
Although I haven't had any issues at all....There's certainly no harm in running one !
The spring setup we (jak9922,solrus and me ) have puts the shock at 45 degrees in the rear...
That angle changes the effective spring rate...
Multiply spring rate by .71 for 45 degrees shock angle
So the 425HD are 485/225 spring rate
485 x .71= 344 (actual spring rate)
It would be nice to know what the stock rate is to compare.
pFive
pFive
670
1,267
Greenwood IN
Wait, do they make the Arched arms in a wider width? I have only seen the standard width for the stock length axles?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i know in some of the pics it looks wider because of the rims and tires that are on them but i dont know if the actual lift adds width to it
Reactions: Dp5hunter
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Im thinking about having you do the front at takeover, just wondering from that perspective if I should remove the rear sway bar.
that depends on your riding style if you ride fast and like to push the machine id leave it on if you are more of a slower like to rock climb ect remove it you can always put it back on if you dont like it
Tigermark
Tigermark
Outside looking in.
Ok thanks, I think I will disconnect it and experiment with it . I will PM you and discuss the front replacement.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i wont have the shocks stocked but if you brought them with you i could put them on in no time
Reactions: Montecresto
solrus
solrus
1,629
2,511
Montana
if you want to run the progressive front shocks send me your front upper a arms to relocate your lower shock mounts and ill send back with the new shocks 450$ includes shippingView attachment 31028
How much will be work only without front shocks?
chrisC
chrisC
138
259
The outkast fabworx 3" lift needs a 2" wheel spacer in the rear and the front is still 3/4" wider than that! That would be too much mud slinging for me!
The kit is able to use stock front axles because instead of the stock setup where the axles are angled towards the back....the Outkast lift have the axles going straight out of the differential. Wider....
the kit has front upper and lower a arms and rear lower a arms
$700
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
$700
makes sense i havent looked that far into them
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i have to relocate your shock mounts so i have to cut and weld on your upper arms then its just a bolt of for you
