P1000m5 Help with Elka stage 3 and 30" tire
Surveyor
75
240
Auburn, MI
Got the heavier springs installed and a semi-agressive 44 mile ride on them. Still some rub on the rear tires but much less. It actually rides bumps and handles better all around this way.
Sent from my SM-S906U using Tapatalk
266,479
What offset wheel are you running and tire width. You may need a 4+2 or 4+3 offset with wide square profile tires to avoid rubbing.
Surveyor
75
240
Auburn, MI
The rub is the rear tires so the offset really isn't a factor, but they are 5+2 front and rear.
266,479
Tire size 30x10x14 with a square profile vs oem rounded may need to add 1" spacers to rear. If all 4 wheels are 5+2 offset the rear is 2" narrower than the front. Or put 4+3 offset wheels on rear for correct track front to back.
That should also negate the spring rubbing. OEM offset on wheels is 30mm front and 50mm rear (26mm being approx 1")
107,302
Like @JACKAL said, get spacers to fix the track and your set.
Surveyor
75
240
Auburn, MI
I have spacers. No tracking issues. The rub is simply the top of the rear tire hitting the bed. The only cure is smaller tires or slow down.
