P1000 Honda Pioneer 1000 Maintenance Schedule
perry
perry
191
168
South Dakota
they do not list any thing for any year that i can find. Some were I found that the KN-114 fit the oil! was just wondering if any one knew for sure.
Reactions: Lady01
Worm237
Worm237
19
36
Atlanta, Ga
Honda service guy said the 1st initial service cost was 2.5 hrs and $600+ dollars? Holy crikey is that possibly correct?
Reactions: Lady01
Neohio
Neohio
Beast of the East
13,342
64,857
Painesville Ohio
If you follow the letter of the law in the manual and have your valves checked.
Most guys do their own services. For right around $100, you can service your rig including the diffs.
Reactions: Lady01
Worm237
Worm237
19
36
Atlanta, Ga
The service guy did say the valves will have to be checked. Anyway no sweat off my balls, I have the pre-paid maintenance agreement but I was just wondering why the $600+ for a 2.5 hr service. I mean the most effort put into the service is checking the valves! The rest is air filter inspection, oil and filter, tires, safety checks, etc etc etc right?
Reactions: Lady01
Neohio
Neohio
Beast of the East
13,342
64,857
Painesville Ohio
First service will only include engine oil.
Diffs and sub trans aren't recommended until much later.
What did the service plan cost? For how many years?
Reactions: Lady01
Worm237
Worm237
19
36
Atlanta, Ga
There were five package levels at different prices that covered different maintenance, motor/trans/accidental UTV damage. I got the top package, platinum, at $26 month. My maintenance package covers the first 6 services in 48 months. Engine and trans are covered for a "life time" as long as you keep up the annual maintenance as described by Honda. It is also transferable to the next owner. Sounds good but he company is in New York so I suspect that the first time I go over a prescribed service and then have a problem they will say I did not adhere to the contract and refuse to pay a claim. Therefore............I plan to stay on track with whatever is required so the yankee sons of b____ don't screw me.
Reactions: Lady01
Weezil
Weezil
South Carolina
My wrench icon lit up over the weekend and so I called to schedule break in service. Luckily they didn't say $600 but $225 is still high. Me thinks I may change all the oil myself and adjust the valves if I hear 'em tappin
Reactions: Lady01
Neohio
Neohio
Beast of the East
13,342
64,857
Painesville Ohio
If this is your first service, they will only change the engine oil.
They will not change the subtrans oil.
Doing the job yourself is easy if you have changed oil before. It wouldn't hurt to change the engine oil and DCT/Engine filters, sub trans oil, front and rear diff oil.
Will give you a chance to get friendly with your machine and ensure everything is done correctly.
The 1000 platform has been out for quite some time now, but I have read in the past of techs draining the sub trans during oil changes and not refilling with oil. @Tramguage1 comes immediately to mind.
Reactions: Lady01
dojo
dojo
26
26
New England
hey guys, considering buying a used pioneer p1k-5 that's got 700 miles on it, and all the accessories I want.
Initial maintenance was dealer serviced, but since that's just oil and filters, i'm left wondering how important swapping out gear oil, coolant, and brake fluid is on the 2 year interval, regardless of mileage.
Replace the following items regardless of mileage:
Front and rear final gear oil
Engine coolant
Brake fluid
the seller of the used pioneer is obviously leaning towards it is not important and dealer is trying to make extra money.
but I'm wary if that's the whole story. I'm OK to service it myself, but would like to get some input from more experienced folks about the importance of this fluid rotation every 2 years.
i'm looking at a 2016
Reactions: Lady01
Mudwing
Mudwing
36,959
306,563
The Mud holes
I’ve got a ‘17 700-4. I change my gear oil every year. I ride a lot of mud and water. It’s cheap and easy. Good insurance. You can test the coolant to verify if it needs to be changed. Brake fluid is hygroscpic meaning it absorbs water. I haven’t changed out the coolant or brake fluid yet but I don’t have any indication of a problem. I would check the levels before you buy. If they’re good, then it’s not a deal breaker for me. Hope this helps. ;)
Reactions: Lady01
dojo
dojo
26
26
New England
what's the preferred way to test the coolant?
i suppose if i'm happy with the braking system and it's not spongy - i could wait a bit on the brake fluid.
but in terms of the gear oil, i'm not sure about changing it every 2 years regardless of usage. seems like it could be wasteful.
but then again if the guy is rocking original gear oil, after that 700 mile break in it is good to change
Reactions: Lady01 and Mudwing
Mudwing
Mudwing
36,959
306,563
The Mud holes
04F38C1B 9A0B 4602 8D43 DB66C8A3DC11
I use a refractometer to test coolant. Works good. I’ve never used the bulb thing on the left. As far as gear oil, I change every year because it’s vented to the atmosphere and the possibility of water in there from riding is real. Just for the sake. It’s always clean. I’ve changed it twice already. Mudding habits. ;)
Reactions: Lady01 and dojo
Jsquared
Nashville TN
Does the first post show as a bunch of code and basically unreadable for anyone else? Can someone post a pic of the maintenance schedule for the 1000-5? Thank you in advance
Reactions: Lady01 and Hondasxs
WagginTail
WagginTail
1,473
5,443
SC
Do you have your owners manual? It's in there. If not I can take a pic of mine this evening
Reactions: Lady01
63,464
I'll work on it.
Reactions: Lady01
PJon
PJon
760
3,055
Arizona
Engine coolant
Brake fluid
Changing the diff oils is not a big deal. Both drain plugs drop straight down. The sub trans is a bit messy. The drain plug is horizontal and the hole in the skid plate is not long enough. If you want to avoid an oil lake on top of your skid plate, take the skid plate off before changing the sub trans oil.
BamaDave
39
112
South Alabama
I need to do my 1st service o my 1000-3, does anyone have the service instructions to break this down for me? I ordered this kit
Edwards Oil Change Kit fits 2016-2021 Honda Pioneer 1000
PJon
PJon
760
3,055
Arizona
Your owners manual shows where the drains for the engine oil are; explains the oil & trans filter location and also has a chart showing recommended service intervals. If this the 20 hr/100 mile service, don’t get too concerned with checking valve lash. The owners manual states that this is only necessary if the valves are noisy or the machine is hard to start. Last item - make sure that you don’t drain the SUB TRANSMISSION accidentally.
P1K5Dave
P1K5Dave
2,162
8,086
Petoskey, MI
Those oil drains do tend to confuse the shat outta ya when you first maintain a P1K
Reactions: ChadD and Lady01
