What's with this procedure to check the oil level?
I was not getting consistent readings so I used a stop watch. Ran it for exactly 5 minutes then turned the engine off and tested at the following times:
1 minute - hit the lower mark on the dip stick
2 minutes - about 2/3 between upper and lower marks
3 minutes - at the top mark
4 minutes - over the top.
WTF... are we supposed to carry a stop watch. Then if its low you have to add a couple ounces and run it again for 5 minutes.
Others may take issue and say it's just good common mechanical sense to do so to be safe.
But call it being tired of checking something I know to be accurate and always was when I used to bother checking it.
If it takes 6.1 quarts of oil with both filters being changed and you KNOW you put in that exact amount of oil and you KNOW it was completely drained properly, I see no point in checking it after.
Fact, I think it leads to over thought and over concern about an ounce here and an ounce there. Mathematically, 6.1 is 6.1 is 6.1. Once 6.1 is installed, why bother checking that 6.1 was installed?
I actually trust the jug marked 1 gallon much more than my dip stick on a vehicle
My truck takes 10 quarts with filter and my containers come in the 2 1/2 gallon version.
Once I fill it, I move on and never check. Because I know for a fact I have 10 quarts in.
I do ALWAYS check later on around every few fill ups just to make sure I don't have a leak or excessive usage. And on the P1000 probably more often till I'm satisfied all is well.
But initially I think it's just time spent for no other reason than its just become an accepted practice on ANY vehicle fluid change.
I'm sure there are horror stories out there about guys who forgot to screw on the oil filter or forgot to tighten the plug and checking it saved their butt before they cranked it, I don't know.
For me? I'm moving on
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
