P700 Hunting Front Rack / Bow Case
NewHere2
NewHere2
Village Idiot In Training
36,236
307,456
High Plains of SD
While hunting in the 700 last fall, it seemed like I just didn't have enough room. Throw a couple tree stands in the back, a pop-up blind, and a cooler. NO ROOM !
Where the heck do you put the bow cases ? Our state requires a bow or firearm to be cased when transporting them. So I decided to try my luck at a "Front Rack".
Figured one made from aluminum would save on weight and make removing it easier when I need to access under the hood.
Using an old bow case as a pattern, I attempted to make an aluminum basket to hold the case. This was my first time working with 5/8" aluminum rod. So we won't talk about the practice bends, or what they cost! LOL ! Well, the basket finally took shape.
IMG 2601
IMG 2609
The basket is 48" wide x 24" deep at the widest part, with a 3 1/2" railing. Add a front mount that extends down to the top front bumper tube and mounts with two quick release clamps rated at 165 lbs. each.
IMG 2608
The entire basket and railing is made of 5/8" round aluminum rod. The mesh is 3/4 x 9ga. aluminum flat diamond stock. Two aluminum flat straps were bent into an odd "L" shape to mount against the windshield. These mounts and a tightening knob hold the rear of the basket. Off to powder coating to give it a good look .
IMG 2664
Above is a close up look at the windshield bracket.
IMG 2662
The entire project turned out much better than I expected. As a bonus, I now can tell exactly where the front corners of the 700 are ! This mod, along with the storage box, dual battery setup, electronics and dual winching capabilities posted in previous threads will make life tougher for the Elk !
Hope these ideas help you folks!
NewHere2
NewHere2
36,236
307,456
High Plains of SD
The QD Clamps that mount on the top bar of my 2018 front bumper are from B&H Photo :
Works great! I believe it has a 165 lb. rating per clamp. At $12 per clamp, not a bad deal.
Russ989
Russ989
22,592
146,756
Nice work, that looks great!
