P1000 i4WD Modulator ?
bumperm
bumperm
1,856
6,671
Gardnerville, NV
I'm having an intermittent failure to shift out of 1st gear. Error code is 5 - 2. I've checked fuse as per service manual. Next thing to check is i4WD Modulator connector. I can do that . . . if I can find it.
Dumb question . . . I sure would appreciate some help and direction in locating where the i4WD modulator is. I.e. approximately were is it? The diagram drawings in service manual aren't a lot of help until I can see the darn thing (I've had some heart damage, I think due to Moderna vaccine, and I need to be efficient in preserving energy if I can.)
Thanks much for any help.
64,595
Here is some old info on code 52. Neutral Switch Failure.
But no followup from the OP.
64,595
bumperm
bumperm
1,856
6,671
Gardnerville, NV
Well, removed the neutral switch and checked it with my ohm meter. Shows open from ground (theads) to terminal with button not pressed. With button pressed, reading vary between open to 4 or 5 megaohms at best. I'm assuming with button pressed is should show continuity (i.e. ground).
Where's the best place to get one?
Thanks for all the help, btw. I will report back on this, but assume it's the problem.
906UP
906UP
13,321
124,954
da Yoop
This is a dealer item, call your local dealer or order one online from RMATV, Motosport, etc
