P1000 Interco sniper 920 radial tires
Bogator
14
19
Louisiana
Has any one put on or running the 31x10-15 or the 32x 10- 15. On a 2018 pioneer 1000 LE also what mods did it take. I know they run small
Reactions: JenElio
107,320
Tons of info on these in the search up top.
Just a small taste
I think there is one you asked a bunch of questions on before In there.
IMG 1408
As for your size and mods needed,
short answer: If your going any bigger than 28’s and your still stock, arms etc. you will rub and be back here asking why?
Losts of info again up top about that as well.
Robobrainiac
Robobrainiac
2,464
8,600
I bought the 30x9.50r14 interco sniper 920. I put them on my beadlock wheels. I think that was last year. I still haven't put them on my machine.lol.
Anywhos
I do run the Achilles Desert Hawk MT 30x9.50r15. I required the C-Fab arms with lift. If I remember correctly, it moves the axles forward 2" and gives 3" of lift. I clear my 30s well. I don't think it would clear 32s.
The most typical limiting factor is the distance from the body/frame from the axles that limit tire height. A lift on the machine does not yield as much increased tire size as moving axles away from the body.
I would not think the pioneer would move 32s easily without minimum a tune. I would imagine IGR or portals would be needed to run 32s easily.
Robobrainiac
Robobrainiac
2,464
8,600
C-Fab advertises 32s fit with the arms I have.
StewB
StewB
674
3,117
Sorry this is moderately off topic: I have about 150 miles on my new Sniper 920s - stock size at 27-(9 & 11)" R14.
They have noticeably less rolling resistance than the OEM Bighorns at the same psi.
Good luck.
