P1000 Lt tires and rims
Robobrainiac
Robobrainiac
2,472
8,644
I was planning on going with the 235 75 r 15'' tire (not sure which tire yet) same size rim on all 4 corners. Im just not sure what off set I need !! Anyone know this ?
My vision 14" beadlocks are a +54. I think it calculates to a 6.1" + 0.9" wheel.
My Falcon Ridge 15" wheels are a +30. I think it calculated to a 5+2.
Both sets could have had more negative offset and I would have been happier. I would recommend a 5+2 wheel. I made both sets work for me with 1.5" spacers on front and 2" spacers on the rear.
Reactions: ChadD
A
anberoka
9
82
Alabama
  1. 1000 6 Crew
I chose to go with the "clearance priced" Falcon Ridge 15x7 rims from High Lifter and "Forceum M/T 08 Plus LT 235/75R15 104/101Q C (6 Ply) MT Mud Terrain Tire" from Priority Tire. For a set of 5, which gives me a matching spare. I also added RB3's 1" spacers in the rear and the track seems perfect. The Falcon Ridge wheels do require a splined lug nut and tool, available on Amazon for less than $20 (seem to be decent quality "Chinesium").
I was all in for less than $1,050 shipped, delivered, then locally mounted and balanced. My 2023 1000-6 Deluxe Crew is primarily driven around our lake community, and these LT tires are much quieter and smoother riding than the factory setup. No suspension changes required and the 235/75R15 tires stand just under 29".
M03GEg1NMJX5zlTmIVuFrN4w1119 h839 s noauthuser0
4ORgZA9 hJVF1FrVA7UufZX8w687 h916 s noauthuser0
S1by W3GvnRTyZuVqdzytj48w687 h916 s noauthuser0
107,956
I was all in for less than $1,050 shipped, delivered, then locally mounted and balanced. My 2023 1000-6 Deluxe Crew is primarily driven around our lake community, and these LT tires are much quieter and smoother riding than the factory setup. No suspension changes required and the 235/75R15 tires stand just just under 29".
Those look good!
Yeah i knew there was a 235 size that would get you to 29”
TripleB
TripleB
11,988
101,948
Caryville, Tennessee
They will rub at full turn and a little compression of the suspension but not enough to matter. They may never rub on good blacktop roads though.
Robobrainiac
Robobrainiac
2,472
8,644
I am happy to hear someone else was able to take advantage of the cheap falcon ridge! They look great!
TripleB
TripleB
11,988
101,948
I had them in my cart for weeks from 2 different places and never pulled the trigger until it was too late. Dude sent me a link a couple of weeks before you posted them. When he sent the link they still had the 30 inch mud tires for a tad over 100 bucks a piece. They sold out first and then I started to buy those 28s you listed because they were such a good deal but missed out.
Scoop
Scoop
4,272
16,007
  3. Talon R LV
Procrastination saved you some money!
Reactions: Robobrainiac
