Jackson Turbo new firmware
Brazula4life
74
Florida
Can't get the oil feed line or return line to turbo from leaking, very small leak but can't figure it out which line is it or how to stop it.. How tight do I put those those hoses?
HondaTech
Make sure the block they go into isnt leaking instead.
Moto4
46
51
Vermont
Mine had a small leak at the at the high pressure line fitting. I could not get good access to the fitting with my regular open end wrench. The outside edge of the wrench would hit against the return line fitting. I tried grinding down the outer side of the wrench but I still had trouble getting the right angle with the wrench. I ended up getting a set of angle head open end wrenches, ground the wrench a little bit and was able to tighten the fitting. That fixed the leaked. Hard to describe how tight but it's a high pressure line so it needs to be fairly tight.
Reactions: Montecresto
N8theGR8
N8theGR8
74
Central Texas
Do Talons have high-elevation issues with maintaining low end and torque? I have a Pioneer 700-4 but want to get into crawling/climbing sometime in the future and would need that suspension travel? Thanks!
34,174
Yep, and the 700 was real bad with no low range.
