P500 License plate brackets?
A
arachnyd
24
82
I for the life of me can't find a decent license plate bracket that works well for these things. I have a 500 but would prefer to be under the plastics and not above.
Right now I'm just zip tie but I hate it. It bends when I drive, slides a bit, and gets hit....
Reactions: Rdrcr and Buggyman
HiFive
HiFive
626
2,547
West Central Fl.
This is how I attached a plate to my p5. A 2x4 attached to the Honda tray accessory.
IMG 20230304 200253 IMG 20230304 200229
Buggyman
Buggyman
35,426
301,696
ne. ohio
I made a small bracket and bolted to a existing hole in the frame PXL 20220328 1921235494
Buggyman
Buggyman
35,426
301,696
ne. ohio
Now I'm curious how you have a full size plate and not an apv plate in Ohio... Is that an agg plate?
no it's a regular plate just like your car. you can download and print form 1373 ( I think ) or they have them at the sheriff office. make sure your sxs meets the requirements and have the sheriff inspect it and sign the form then you can get it retitled then get regular plates. you will be limited to roads 35 MPH and under. The title office here in summit county was a B##ch and refused to do it so I went to Wadsworth office they were very nice and I was completely done in about 15 min. Big shout out to @Neohio for all his help and info on this
Screenshot 20230305 072356
A
arachnyd
24
82
no it's a regular plate just like your car. you can download and print form 1373 ( I think ) or they have them at the sheriff office. make sure your sxs meets the requirements and have the sheriff inspect it and sign the form then you can get it retitled then get regular plates. you will be limited to roads 35 MPH and under. The title office here in summit county was a B##ch and refused to do it so I went to Wadsworth office they were very nice and I was completely done in about 15 min. Big shout out to @Neohio for all his help and info on thisView attachment 377032
Nice!
Reactions: JCart and Buggyman
13,468
66,406
Ohio inspection didn't require a plate light, so I opted to not install one. I have yet to be given trouble over it.
bowhunterbill
bowhunterbill
414
1,281
Bozeman, MT
I think I bought this with leds on top at the dealer. The best part is since it’s mounted on the sloped portion, the leds illuminate to the rear and give me a little more rear facing light at night so drivers behind can better see me. I ran a wire from the front to power it.
00277a85edee3b6bf27f3b9add3aa5a4
The_Frontiersmn
15
23
Minnesota
Mine came from the dealership with the factory accessory rear bumper installed, so I just attached my plate to it with a couple cable clamps.
Reactions: Buggyman
K
Kilroy
92
284
Look at trailer plate brackets for those that use a full size plate. Aftermarket motorcycle plate mounts can work for the smaller plates.
Reactions: HiFive and Rdrcr
