P1000m3 Lug Nut
Travis R
Travis R
135
441
Southeast Louisiana
I guess I’m posting in the right forum, idk.
Anyway, I have a 2016 Pioneer 1000-3 EPS. It has 14” MSA M12 wheels on it (no wheel spacers). I lost one of the lug nuts and don’t know which size to order, or where to order from. The lug nut is black.
Any ideas?
Thank You
109,548
906UP
906UP
13,327
125,006
da Yoop
It's worth mentioning, the taper type depends on what wheels your using. Aftermarket use a 60° taper, oem Honda wheels are a "bulb" rounded taper thing....or something like that.
109,548
You are correct sir.
He has MSA’s thats what i have on my P1 and Talon. The ones i posted are 60’s like the MSA origonals so he should be good
109,548
This is what I’ve decided to order. I hope it works.
MIKKUPPA M12x1.5 ATV Lug Nuts - 16pcs 12x1.5 Aftermarket Lug Nuts Black with 19mm Hex, Compatible with Polaris Ranger XP RZR 900 1000 General 1000 Pioneer 500 700 1000 https://www.amazon.com/dp/B0BXKXD299?tag=sxsweb24-20
Ahhhh are you sure you dont have spline lugs like the ones i posted?
MSA’s use them unless you have a weird set im not aware of?
109,548
Another reason they use the spline lugs is cuz of the narrow openings in there wheels to give them a more finished look. The standard acorn lug nut will not fit in there, they are too big. If u can post your wheel, i can check for you if u like
Travis R
Travis R
135
441
Southeast Louisiana
You are 100% correct. I went and looked at the wheels. They are splined lug nuts AND they are chrome, not black like I originally thought. Luckily I haven’t ordered anything yet. Thank You
109,548
Hay no prob!
Glad we got you fixed up. Anything else just holler
ODAMO
ODAMO
1,202
3,265
Ohio
Ok everybody stand down until we all know what we're actually lookin for......C'Mon man.....
Check to see If Mcgard has what you want. They are thru hardened and MADE IN USA and come in Black or Chrome depending on what you actually have...
109,548
Easy bud! The C’mon man
is a Biden thing be careful how you throw that around.. yikes!
Post a link of your site for the boy then.
FYI I think I already fixed what hes looking for ;) Little late to the party there.
ODAMO
ODAMO
1,202
3,265
Ohio
C'Mon man has been being said before Biden was a thing with you...LoL
Mcgard is the site.
I'm not late, maybe you were premature 😨
Wishy washy queations deserve wishy washy answers, Anyway a little effort goes a long way in getting proper answers and as you like to point out: "Use the search button"
109,548
@Travis R you dont have to listen to The last Couple of posts. Just do what your doin and your good.
@ODAMO you really stepped into a pile of Dog $hit this time around.
Just like your guy, Having to blow things up and not knowing the guy is disabled. Like you said, “use the search”. Nothing that we are talking about to fix his issue is in the search. It was the first thing I looked at before helping the guy, and believe me If it was there i would have posted a link for him like I did with the lugs he was after. I know about your Made in the USA and Im all for that fo sho. But He was looking for 1 lug nut and cant find JUST 1 so why spend a fortune. Let it go for once bro.
His buying what he did isnt gonna kill the economy by himself.
Your man China Joe is doing just fine with that. There is so much wrong with your last 2 posts here, its not worth the effort to answer. Ill let them speak for themselves.
Good day sir!
