Coeus
Major General
Post #2 manWhich one did you get, I've been wanting to do this for a while
I ain't got time for the past, I'm always looking towards the future 🙄😂😂😂😂😂Post #2 man
That's whey more better 👍
Winch isn’t hooked up to that 50 amp breaker is it? If so it’s definitely going to trip when under load. I have a 120 amp between battery and secondary powerWiring almost 100% wrapped up… everything is ran and either zip tied in or staged for tightening… waiting on a couple plates from Crossroads 3D, whip mounts, and need to pick up screws for mounting Auxbeam
View attachment 429535View attachment 429536
Ground bus bar
View attachment 429537View attachment 429538
Turn pro extra wiring.. not sure what to do with them…
Aux/key-on bus bar controlled by DPDT
Testing that runs to back function. Whips and stereo
View attachment 429541View attachment 429542View attachment 429543View attachment 429544
Nope.. it bypasses the breaker since the specs says it can draw up to 250 ampsWinch isn’t hooked up to that 50 amp breaker is it? If so it’s definitely going to trip when under load. I have a 120 amp between battery and secondary power
Looks good young man nomojic.Wiring almost 100% wrapped up… everything is ran and either zip tied in or staged for tightening… waiting on a couple plates from Crossroads 3D, whip mounts, and need to pick up screws for mounting Auxbeam
Ground bus bar
One issue is mounting … it is meant to go over an existing mirror so I need to build somethingThat's whey more better 👍
In my cart, but I'll wait for you to report back on how/if it works 😉
I just ordered a few items that should work… I’ll find out tomorrow/tuesdayOne issue is mounting … it is meant to go over an existing mirror so I need to build something
