Prntdckt's 2022 Talon X4 Build
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
After watching all of you guys put together some great Talons, I decided I needed to give it a try.
My previous 2018 Pioneer project was challenging for me, and I couldn't have done it without the help I got from the members of this forum.
I didn't do a build thread for the Pioneer (and in retrospect I wish I had), so I decided I should do one for the Talon, even if it was posted a few month late.
In August of 2022 I put a deposit down at my local Honda dealer and waited and waited and waited.....December 2022 rolled around and the dealer still could not give a date when he'd have my machine. So I got my $500 deposit back and went shopping on ATV Trader for a new 2022 Talon X4. Two days later, Rod's Powersports in Roca, Nebraska sent me pictures of one he had in his warehouse, new with 6 miles on the odometer. Looked kinda dusty for new....It was the model and color I wanted so I told him I wanted it.
. IMG 20221202 2045201IMG 20221202 2045281
A few days and 525 miles later we picked it up. Dealer prep & cleaned up good
20230417 202501
Back in the shop at home and begin modifications....
IMG 20230416 2009461
It will take me a while to sort thru my pictures to post the build in somewhat chronological order.
More pix to come
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
Put the talon up on the rhino ramps to work on the inferno heater installation.
Removed the Honda "skidplate" in preparation for a future Factory UTV skidplate and rockslider installation.
Got the under chassis plumbing in place
20221220 141254
20221220 185202
20221220 185238 20221220 185625
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I liked how the Inferno heater mounted under the hood. Pretty good access for the ductwork install
20230101 174033
Got the Samsung tablet moved over from the Pioneer. Installed an 8 gang Auxbeam switch panel for accessory control. Also installed a number of Ram mounts for cellphones, etc.
20230101 174045
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I opted for the Honda OEM lower doors. Its some finicky work cutting and grinding the upper door panels to install the lower panels. I was glad I purchased a 1" belt sander. It made quick work of the modifications need to attach the lower panels
20221231 161427
20230101 171713
20230101 172006
20230101 172344
20230101 172355
20230101 173951
20230101 174022
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
After getting opinions from forum members, I went with CEC softsides for the Talon.
They fit well. The zippers appear to be extremely heavy duty and should hold up well.
Sure hated to drill holes in the doors for the snaps, but after the first one I got over that.
20230101 214158
20230101 214211
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
After a month of vacation on the Texas gulf coast, it was time to get back to work on the Talon
Installed the front A arm and trailing arm skidplates from Factory UTV. They fit real nice.
20230307 214618
20230307 214640
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
With some help from my neighbor, got the Dirt Road Fabrication bed exiender installed.
What a well-built accessory this unit is.
I ordered it with the optional fuel tank mount plate, the expanded metal bottom, and the low tire mount.
Shipped in a shipping blanket wrapped with stretch wrap.
Made the journey from Utah without even a scratch.
20230412 1552531
On our last club ride in December, one of the guys cooked his lunch in a 'MuffPot" strapped to his exhaust pipe
It worked so well I figured I needed one too
Its large enough to heat up a couple of burgers, or four hotdogs.
20230412 1552531
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
When I was installing the hoses for the Inferno heater under the chassis, I noticed a large open area under the pasenger seat, and thought that would be a great place for a second battery. Had some scrap aluminum angle in the shop and fabbed up a battery frame to bolt between the frame tubing under the seat.
20230405 2309591
20230405 1712421
20230408 1610281
20230410 1438041
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
Removed the OEM poor-excuse-for-a-bumper and installed a Bosman Bumper
20230413 1854031
What a big improvement, and should be able to bolt up a Badlands Apex 5500# winch to it.
20230413 191124
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I got around to installing the Badlands 5500 lb long spool winch today. Its a tight fit, so I removed the bumper to install the winch.
E4D01F98 030C 41B5 95BF 9488FC744DCA
The Bosman bumper has the appropriate mounting holes so no mounting plates or modifications are necessary. Just bolt it up.
2B7D715D AF14 4F08 AA37 35BBE7CCD0D5
6F47CF3B F839 4430 BCD7 9F476610E4AC
I was working today without help, so I found using a floor jack was handy for installing the assembly. A second set of hands would have made the project easier.
CDDCAD1B E8A8 412A A196 4376296D5F33
I installed a plastic panel for the winch contactor and other electrical components under the front cowling.
A
E661610D 5DED 4B0F B2B9 7CF53B9F158C
208,011
I got around to installing the Badlands 5500 lb long spool winch today. Its a tight fit, so I removed the bumper to install the winch. View attachment 384174
A
I used C clamps and a heat gun to make the bend.
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
Finished the installation of the Factory UTV skid plate and rock sliders.
I ordered the 1/2" UHMW kit with the 6061T6 aluminum reinforced rear skid
20230422 180028
I found using a ratchet strap was useful in persuading the formed UHMW parts into place to get the fasteners in place in each component before tightening everything up.
20230424 164345
I enlarged the center hole in some of the dished washers to facilitate alignment. The finished product looks good.
20230424 202137
The rock sliders should protect the sides well.
20230424 202159
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
Replaced the OEM tires and rims with 30x10x15 Tusk 10 ply Aramid Terrabites and Tusk Unita wheels.
20230527 210507
Purchased a 5th Terrabite and mounted on one of the OEM wheels as a spare
20230527 211025
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
The OEM Halogen lights don’t put out enough light, so I added a 12" light bar. It mounted up nice on the Bosman bumper.
20230527 210941
