Prntdckt's 2022 Talon X4 Build
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
Added a few Auxbeam rear lights also.
20230527 210857
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
UPS delivered the Honda cargo box I ordered from Ron Ayers this afternoon.
20230527 205654
I got the two mounting plates in the bed.
20230527 205705
There are four hooks that are mounted to the bottom of the cargo box that attaches it to the mounting plates.
20230527 205816
After attaching the box to the mounting plates, Honda provides two locking collars to securely fasten the cargo box in place.
20230527 205929
Finshed install looks good.
20230527 210414
The cargo box provides plenty of space for tools, parts and supplies
20230527 210344
Its an expensive accessory, but I'm happy with how it turned out. It fits perfectly, and it's water and dust tight.
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I ordered the Dirt Road Fabrication bed extender with the optional mount plate for mounting a gas can. I picked up a front loading mount for the Wavian jerry can I had on my Pioneer. I fabricated a 3/8" aluminum plate to adapt the Wavian mount to the DRF mount.
20230730 201609
20230730 202004
20230730 202019
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I installed a wye and two valves to control of water from my oil cooler to my heater. I am able to stop all flow to the heater core in the summer, and adjust the bypass flow back to the engine loop if needed.
20230730 210700
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I tried disconnecting the sway bar links as some in this forum have suggested, and liked the improved ride at slower speeds. I decided to install the Speedway shocks that other forum members have used so I didn't need to worry as much about body roll at higher speeds. They have worked out well.
20230730 210708
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I wasnt totally satisfied with the turn signals, so I installed a Signal Dynamics self cancelling turn signal module and interfaced it to the Auxbeam panel. I changed the mode of the outputs to momentary, and installed some turn signal indicators in the new overhead console.
Screenshot 20230730 214347 Amazon Shopping
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
When I put the battery isolator and second battery in, I installed two dual usb chargers, each with a voltmeter to monitor the primary and secondary battery voltage levels. I also installed an over-ride switch to operate my accessories without the ignition switch on.
20230730 213657
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
What's that port in front of the GoPro mount?
20230730 213816
It's a manual disconnect switch for the winch. I leave the switch open except for when I'm actually using the winch..
20230730 213908
Prntckt
Prntckt
1,049
7,225
Altoona, WI
  1. Talon X4
I had a few questions asked about the overhead cooling fan I installed in my Talon.
I mounted a 12 volt DC radiator fan on some 1-1/4" x 1-1/4" x 1/8" aluminum angle secured by pipe clamps.
20230801 151158
I used a 12" radiator fan purchased from Amazon.
Screenshot 20230801 190414 Chrome
I tried a few different varieties of cushioned pipe clamps. Many did not hold the cage tubing tightly. I ended up purchasing these from McMaster Carr.
Screenshot 20230801 185740 McMaster
20230801 151128
20230801 150639
It's relatively cheap and works well.
I experimented with the distance between the roof and the suction side of the fan. You can mount it too close to the roof, and affect the fan's output. I have the suction side of the fan about 2-1/2" below the roof now.
I plan to add a second fan above the front passenger seat, and add a PWM DC motor speed controller to vary the speed of the fan.
20230730 000000
20230801 150623
