JenElio
Just curious 🤔 why not wire it directly to the key-on 12V busbar or similar?Power converter from 12v to 5v ordered with arrival on Thursday
12v vs 5v… it will be wired directly into the Auxbeam but need to step down the voltageJust curious 🤔 why not wire it directly to the key-on 12V busbar or similar?
POIDHPower converter from 12v to 5v ordered with arrival on Thursday
Did you find a factory winch ground cable? I found the positive cable, but have not found a ground.
No ground… they removed it and have a mount point up front that I tapped intoDid you find a factory winch ground cable? I found the positive cable, but have not found a ground.
exactly where i used. Just making sure I didnt miss somethingNo ground… they removed it and have a mount point up front that I tapped into
