Mirrors with SATV soft enclosure
F
Firedad
46
103
Reno, NV
Still haven’t come up with a solid idea for adding mirrors back to the talon since adding the SATV enclosure. Unless I drill more holes in my windshield frame or cut into the enclosure fabric I don’t see how or what mirror system will work. Anyone else have this figured out?
Reactions: TxDoc and Smitty335
F
Firedad
46
103
Reno, NV
Right after I posted I went in the garage and looked at the mirrors I had previously bought and came up with an idea. I have a bolt through my SATV glass windshield frame holding light pods on either side so I’ll drill a second hole on either side to mount a 1-3/4”x5” flat stock bracket to mount the mirrors to. This will work. I’ll post pics when I get around to it next weekend
113,618
Why next weekend? Why not now? 🤣
Either way, were gonna hold u to it!
Im getting ready when i finish my front porch to do what @906UP did
906UP
906UP
13,990
132,058
da Yoop
  3. Talon X
Here's what I did to put mirrors on the Honda accessory doors, welded in some flat stock to the frame then bolted through the canvas.
20230723 170709
20230723 170658
113,618
I took my doors off for the summer, sending the drives canvas down to @Ridinfool for zipper repairs 😬
Oh boy. You’ll have that sometimes the zip outdoors.
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
F
Firedad
46
103
Reno, NV
4D039B30 6933 4F29 A016 06B113D36268
Ok so instead of buying flat stock I found two of these. I’ll paint and slap them on and boom, I’ll have my mirrors again. It’s steel so they should bounce while driving and they’re long enough I’ll be able to see them but not too long I’d worry about hitting them on anything. Going to use the bolt for the pod on each side and I’ll drill a second hole to mount the bracket. Only concern would be if I did hit anything with the bracket is that it’s attached to the windshield. That wouldn’t be good.
3DAA52F3 20A1 4EAB A82A ED376B7C46E9
113,618
View attachment 397102Ok so instead of buying flat stock I found two of these. I’ll paint and slap them on and boom, I’ll have my mirrors again. It’s steel so they should bounce while driving and they’re long enough I’ll be able to see them but not too long I’d worry about hitting them on anything. Going to use the bolt for the pod on each side and I’ll drill a second hole to mount the bracket. Only concern would be if I did hit anything with the bracket is that it’s attached to the windshield. That wouldn’t be good.
Well $hit! Sorry I didnt pay close enough attention, you have SuperATV soft doors.
Everything we tried to help with you dont mean $hit to you anyway 🤣
So It dont Fuc others up, change your title to “Mirrors for SATV soft enclosure for Talon”
It will also help others in the search when they need the help as well.
Reactions: Smitty335 and ChadD
F
Firedad
46
103
Reno, NV
Title changed, also had another idea. So I don’t have to drill into the windshield again or worry about if I hit the mirror brackets that it’ll damage the windshield, I’m going to go low on the A pillar and cut the roll bar clamps in half so they’re narrow enough to fit in that tight spot below windshield frame.
CD9691AB 89D1 4668 A574 78902A3E7EA7
F
Firedad
46
103
Reno, NV
Going to work late so probably won’t install tonight but pretty sure this will work for now.
Reactions: SuperATV
F
Firedad
46
103
Reno, NV
It’s a work in progress still. Need to fix the bracket to fix the angle on it and will play with the possibility of shortening the bracket. As long as I can see the mirror past the enclosure but have the bracket as short as possible. So far the only thing I like about it is it’s not attached to the window frame. The rest I really don’t like, looks stupid to me
8C4CFCA5 20B1 4C06 8675 4995B3CB681B
61656A54 3470 49B0 AF51 337C644D71D9
F
Firedad
46
103
Reno, NV
IMG 4182
Finally finished both mirrors. Not what I want, so I’ll keep looking for an appropriate product or come up with a different solution, but until then this works and doesn’t look stupid. I have a hunt coming up so not enough time to worry about it.
While I was working on it I started adding some weather stripping to keep some of the dust out. This is definitely going to be a work in progress
IMG 4182
