P1000 My 2021 1000-5 Build…so far
Scottfsu
9
48
Florida
SuperAtv front and rear a-arms
SuperAtv Heavy Duty Axles
SuperAtv lift kit
SuperAtv windshield
SuperAtv 6000lb winch
Dual Battery, fuse block, dual Stinger relays (allows use of a hidden push button for aux power wout key)
Dash kit w - Boss stereo, switches, volt meter
Front 50 inch flood/spot light, rear and side lights, led whip lights, led wheel well lights
Overhead speakers w/ wet sounds AS-8 subwoofer under seat
SuperAtv snorkel kit
Frontline 556 wheels w 30x10 -14 Frontline ACPs
Mudbusters XL fender extensions
Fox Shocks
Under seat heat exhaust fan
Panel storage mod
Rear dust screen
05B1EEC6 08F5 4D61 A0E7 9DCF1E337298 557E3C4F 7956 4688 A3EF 201555CE5491 B092D2D2 2077 488C 9F19 2CE4C6FEE7BA 419ACD06 A37F 4069 B016 F903FFB0E453 A8B7DBE8 400D 4510 B7F3 B189247262B2 A39F26DA 6CE3 4AD0 9D01 2C1E7B1BB737 58FA600B 43F9 400B 8198 A40BCE99A397 D3983358 B921 4F7A B962 F544C90475EF A4727D2C 5DD0 491A B0FB B21E717BA399
P1K5Dave
P1K5Dave
2,187
8,185
Petoskey, MI
How do you like the Frontlines? I almost got them lasttime around, but settled on the BFG KM3's. My rationale was that these tires were more mud-aggressive than I needed in my normal riding.
I'd like to look at them next time. Sand performance has been below my requirements with the KM3's, but then, these may not be much better there.
Scottfsu
9
48
Florida
I love the frontlines. Mud, trail, and street they’re awesome. Really smooth ride. Sand, they’re ok but do tend to dig instead of float.
Diverdon
50
503
83
NY
Great looking ride. I take delivery of my new 1k-5 in a few days and can’t wait to start a build.
Scottfsu
9
48
Florida
It’s addictive. I’ve watched so many “how to” videos and read so many posts about modifications. The first one I started with was the dual battery set up. I also used 2 relays when I did it along with a hidden push button that activates all the accessories without the key on. FYI…when the key is on, engine hours are adding up.
Once you have the flexibility of 2 batteries, it opens the door for lots upgrades with electronics.
Scoop
Scoop
4,285
16,079
  3. Talon R LV
Scoop
Scoop
4,285
16,079
  3. Talon R LV
Correct. It has nothing to do with supplying power to the OEM electrical circuit (e.g., dash display, initiation, etc.).
My accessories are powered from a fuse box that obtains power from the 2nd battery. That fuse box is energized one of two ways:
When the DPDT switch in the key-on position, the fuse box is energized ONLY when power is sent to the relay (completing the circuit that powers the fuse box) from a key-on power source (a circuit only powered when the key is on).
When in the AUX position, the relay circuit closes (to power the fuse box) because 12v is sent to the relay from an always-on power source (e.g., directly from the battery).
When in the middle position (the DPFT is an ON/OFF/ON switch), the fuse box is NOT powered at all, regardless of key position.
In short, the switch in AUX position powers the relay so it thinks they key is on by using 12v always on power.
