P1000 My PIONEER 1000-5 Adventure.
mlynch001
mlynch001
193
879
Dardanelle, AR
My wife and I have been wanting a SXS for several years now. However, we are both pretty tight with a dollar and simply refuse to pay $15-25k plus taxes for a new machine. Since I worked for HONDA in dealerships for over 20 years and as a Certified Tech for many more years, there was only one choice as far as a brand, that was a HONDA. NO belts for me. I like the concept of the DCT and am very familiar with "The HONDA Way" of doing things.
That being said, We decided that $10k was our limit to spend, if a P1000-5 did not come along at around that price, we were not going to spend more or go into debit for more. I knew if the right one came along, that I could fix anything that might be wrong and stay in our budget. One day a 2016 P1000-5D popped up on FB Marketplace. We called and it was still available. So we went to take a look.. it was a pretty decent looking machine with the HONDA Roof and Windshield and 4000 miles. The battery was dead, so the owner jumped it off and it started, but with a bad rod knock. So the engine needed work. Turns out that the machine had been sunk and run with water in the oil, by someone who wanted to "Try it out and see if they wanted to buy it". After they sunk it, It seems they changed their minds? No problem for me, but a local dealer had quoted him $8000, just to "Fix" the engine. He did not have the Money or the ability to DIY the repair. He needed out from under the payment ASAP. I told him I would give payoff directly to AHFC as long as it did not exceed $6500. Two others were supposedly looking at the machine and were supposed to bring "cash", both backed out after seeing the machine and hearing the terrible engine noise. He let me know that if I still wanted it, he wanted me to have it. It was a "diamond in the rough"! We took it home in August 1 2020 and were on the trails October 15th. As you can imagine, COVID induced delay for getting a title and payoff taken care of, I began to assess the repairs needed. I could not do anything until we got clear title. Once the work began, we found that the engine was just the tip of the iceberg.
Here is the original "To Do" list:
1. Complete engine bottom end replacement and top end overhaul
2. Repair damaged Low/Reverse Gears in Sub-Trans
3. Replace 1-3-5 Clutch Pack
4. Replace both front Drive Shafts
5. Replace Lower Control Arms (bent)
6 Replace Brake pads
7. Replace Battery
8. Replace 4 tires
9. Replace bent front bumper and damaged headlight mount
It took 2 solid days of pressure washing after stripping to the frame to get the mud out of every nook and cranny on the machine. There must have been at least 150 lbs of mud packed everywhere on this poor thing.
The engine needed a new crankshaft, both connecting rods, all bearings and both piston assemblies due to internal damage. It took a few days to get all the metal and debris out of the engine. Engine Parts were on Back order for some time, again due to COVID. I also had carpal tunnel surgery, so I was working with one hand, literally.
R & R Engine. One rod had the big end bearing spun and crank journal ruined. Both rods had the piston pin holes galled from water intrusion and poor lubrication. All bearings were pretty much toast from massive amounts of metal and poor lubrication.
Both Pistons were destroyed and unusable due to galled pin bores. Cylinders were perfect, no wear or scratches (Miracles do happen)
Both piston pins were ruined.
Replaced cam chain just to be safe. Checked and set valve clearance.
Tore down and inspected oil pumps (3). These were in amazing condition, no damage or significant wear. I expected to need to replace all the pumps.
Replaced Oil strainer, it was completely full of metal from the crank and rod.
Rebuilt the Sub Trans with new gears and shift forks. Oil in sub-trans showed contamination from water as well.
Replaced 1-3-5 Clutch and inspected the 2-4-6 Clutch.
Replace Lower Control arms and ball joints along with both drive shafts.
Aligned front end.
Replaced battery and installed dual batteries, since I was adding a winch. I went with a pair of original equipment type batteries, wired in parallel, no isolation. Engine cranks off of both batteries at the same time. This is simple and efficient. No Isolator needed or there to fail. Do not have any desire for sound systems and huge lights, so all that extra stuff was just more work and expense.
Installed Auxiliary Fuse panel, Relay, Volt meter, Rocker switch panel, RAM mount and USB power port.
Installed new bumper and 5000lb XTREME Winch, synthetic rope, KFI Mount and KFI Front Hitch Receiver.
Installed 4 slightly used BIGHORN 2.0 6 ply tires from Kawasaki TEREX.
Cleaned and cleaned some more.
Installed all new graphics.
Installed Grab Straps on roll cage.
Installed Scissor Jack (3D Printed Custom mount).
Installed Fire Extinguisher (3D Printed Custom mount).
Installed inside Rear View mirror. (3D Printed Custom mounts).
Designed and 3D printed Custom Door Hinge Bushings.
Installed Updated Air intake Cover from 2018 P1000 to keep water and dust intrusion down without resorting to a snorkel.
Replaced Air filter and cleaned out mud and water from intake pipe and air box.
Cleaned IACV (full of varnish and mud)
Drained fuel tank and removed a quart or more of water.
Extended all vent hoses and added filters/flame arrestors.
Repaired rear Differential lock. Cable box full of corrosion, cables adjusted wrong and lever on rear differential was jammed with caked mud, rocks and sticks. Turf mode was not working, remained "Locked" all the time
Adjusted brake light switch. (Brake lights stayed on all the time)
Added a roof mounted LED backup light that comes on using the reverse alarm wiring
Added a 15" wide angle LED Driving light bar to front bumper with custom mounts
Added a 10 liter NATO Type Auxiliary Fuel can and Custom 3D Printed mounts in the bed.
Added a tailgate leveling bracket kit.
Adjusted all latches and bump stops to eliminate door and bed rattles.
Made and installed a custom center dust shield out of Marine Grade clear vinyl.
Designed and 3D printed additional tie downs for light items in the rear bed.
Installed storage bin for the wife's "stuff".
Installed DYNOJET PV3 and custom tune (work in progress) UPDATE: 09/15/2021 I have figured out how to get this thing to upshift and downshift the DCT when in reverse. Now I have 2 gears in reverse, 1sr and 2nd. Seems like it is easier to control and less jerky when it is running backwards.
Replaced lower seat cushion due to old one being saturated with water from the times it was used as a submarine. Seat froze solid in winter and was impossible to ride.
Added extensive sound deadening and heat reducing materials to backsides of all plastic panels.
Added isolation foam blocks to roof panel to stop rattles where the roof rubs on the cage. (4 places)
Designed and 3D printed custom front roof drains for that "lake" that forms in the recess of the HONDA roof panel every time it rains.
Installed STRONGMADE Bracket Lift to gain 2 1/2" of much needed ground clearance.
Added double layers of thermal insulation to the front seat bottom and back panels.
Added weatherstrips to rear doors to reduce dust.
Installed Electronic Bilge fan controller and under seat temp sensor for automatic control of upcoming bilge fan(s).
Sealed openings around front seat belt buckle attachments to stop heat intrusion.
Installed RAD Customs Shifter panels and seals, more heat reduction.
Installed additional Heat blocks around the seat belt lower anchor points. Reduced heat flow dramatically.
Added rear door storage boxes under colored panels.
All of these parts cost just a little over $4500 and were paid for the parts as we went along. So we have the PIONEER for just a bit over $11k, total. Not bad and well within what we originally had budgeted. We added a LOT of extras that we did not even consider when we established that original $10k budget figure. This was a lot of work, but I have way more time than $$$. So I looked at the cost of paying someone to do this massive job and figure that as my profit. The dealers are at least $100 per hour in our area so I figure that I have made about $8k-$10k over the course of this project. Plus the satisfaction of doing what most people would have said was not possible.
Things that I still need/want to do:
DONE!! Finish Installing bilge fan(s) for more heat reduction.
DONE!! Chop Roll cage to reduce overall height. To me, the ROPS is way too high. UPDATED 09/15/2021: ROPS Chop completed last week. Photos attached at the bottom of the thread.
DONE!! Install new bead lock wheels and larger tires.
DONE!! Added Center Console for my Wife. She has always wanted a center armrest and a place for more "stuff". It's a "girl thing"!
DONE!! Install UHMW Full skid plate.
Install additional interior lighting such as dash and dome lighting.
Add external access door for driver side under seat storage compartment.
Replace clutch cover with updated parts. (This is new since original post)
Still a work in progress!
Here it is after we started riding the old girl. Also added a ton of photos to the file. These are in no particular order, just to give some ideas of what was done. I wish I had taken more photos of the damage and the aftermath of the destruction. It is impossible to believe the damage that is caused by some water, a little dirt, lack of maintenance and a fair amount of very hard use thrown in for good measure.
1629344198724
63952750809  B2C5678B D5A9 46C5 8E91 F3452BF73C38 63934159692  A8AA149D 5637 479E 804D C05BFA965DE7 63934155348  C73CA146 3CFA 40EA 85FC 7B3021AEF9E6 63918417696  8AC061F5 D100 4959 AE00 A8FF055E8845 IMG 0647 IMG 0645 IMG 0646Edited 62630495143  0ECE4CFE A541 45E2 AF38 2C0F50D004ACfullsizerender 62630491781  8BC0D97C 94B4 4DE0 A320 4682E2135C2Afullsizerender 62517276322  2061BAEE C7B8 41D6 8D88 D4FEB1C76D60fullsizerender 62508364978  B581C269 11DB 4EF7 9155 E3EBA142F9AFfullsizerender IMG 0384 IMG 0383 IMG 0382 IMG 0381 IMG 0380 62326634927  C612CB4A 1624 45B9 84CF 30D952859D57fullsizerender 62318051722  FE89FB3D 6EE0 4D2A 8FC3 07E3CB67F86Dfullsizerender 62317835991  220E1F06 482F 4439 AEAA C0E35C08CBEBfullsizerender 62267117769  D1E3202D 3BC4 4C25 8175 932C60EDAF96 62136353750  DD67F0E2 173E 4F78 95B8 BB2214F581A6fullsizerender 62130184965  593CE5B1 3B5E 4027 9673 42CF80239C83fullsizerender 62075890011  5E9CE030 8DF8 4F89 ADD4 F91E8EB6FABAfullsizerender 62058647277  23554789 269A 4EB4 B956 5AFFE102ECCDfullsizerender 62058642933  514203DF F23B 4FAE 9B90 5EE18D1C38E5fullsizerender 62058639693  4037B184 5911 4A8C A502 40AF4E30463Bfullsizerender 62058637749  BDC17BA3 155D 40AB B18A 382E619D7B38fullsizerender 62058636559  FE9684D7 5E9F 43F8 BA9B 187B20DF2CFAfullsizerender IMG 0327Edited IMG 0324Edited IMG 0323Edited 61997765168  FE950112 C560 4608 A132 2E1F321FB21Efullsizerender 61972825366  7F2C3C42 BD86 4692 96FE FE558C07C2ADfullsizerender 61963623380  70BAF4B8 A2C2 4942 8C5F F49174A53159fullsizerender 61963261028  AC7F9A23 6328 4D7E B007 43F8ECD3FE35fullsizerender 61947216958  8B218237 B635 477F A260 8869E4402BF2fullsizerender 61946149313  3930C714 3B1F 4E39 ABF5 5184FD009756fullsizerender 61888573431  3B0A57F6 9AF0 41B8 818E B8A0D6923CC6fullsizerender 63995434484  F33089A9 B6A9 4A4D 9969 271E7DBA11F6
mlynch001
mlynch001
193
879
Dardanelle, AR
Cool. It being a 2016 I would make sure it had the updated clutch cover.
It has the original clutch cover. The product update campaign is over, and we missed the deadline so unless I buy the parts myself we are stuck with the old cover. So far there has been no indication of problems. We are careful not to abuse the clutch and so far the machine has worked great.. 1200 miles on the new engine and we have been in some pretty rough spots. I will add this to the list of things that we want to do as I did not even think about this when starting the thread.
TripleB
TripleB
11,935
101,321
Caryville, Tennessee
7. Replace Battery
8. Replace 4 tires
Aligned front end.
Chop Roll cage to reduce overall height. To me, the ROPS is way too high. (This is new since original post)
View attachment 290426 View attachment 290471 View attachment 290473 View attachment 290474 View attachment 290475 View attachment 290476 View attachment 290477 View attachment 290478 View attachment 290479 View attachment 290480 View attachment 290481 View attachment 290482 View attachment 290483 View attachment 290484 View attachment 290485 View attachment 290486 View attachment 290487 View attachment 290488 View attachment 290489 View attachment 290490 View attachment 290491 View attachment 290492 View attachment 290493 View attachment 290494 View attachment 290495 View attachment 290496 View attachment 290497 View attachment 290498 View attachment 290499 View attachment 290500 View attachment 290501 View attachment 290502 View attachment 290503 View attachment 290504 View attachment 290505 View attachment 290506 View attachment 290507 View attachment 290508 View attachment 290509 View attachment 290510
If my machine ever needs those kind of repairs, it will just be a parts machine for me. I don't have those kind of skills to do what all you had to do. I was just happy when I got my 2nd battery and accessories installed without someone holding my hand.
mlynch001
mlynch001
193
879
Dardanelle, AR
So, I'm assuming they told you in the ad that the engine was messed up? What were they asking for it?
It's surprising that it would start and run in that condition.
I think the ad said "engine had a 'tick' in it". They were asking "payoff" which he thought was $6500 and I told him I would give payoff or $6500, whichever was less. When I read the words 'engine has a little tick' I knew this was my chance to get one cheap, since the owner was obviously in a jam. I bought it right there, since I did not want him to change his mind. It actually was able to be driven around just a little bit! That just shows how tough a HONDA Product really is! I was able to tell that the main transmission was good and that the final drives were both good. The owner was straight up with me, did not try to hide anything that he knew about the macine. Super nice young man! He just did not realize how much was wrong in addition to the engine. He was at least smart enough that he knew that he could not afford to fix it and did not have the time, tools or ability to DIY the job. I was not at all afraid that I could not get it fixed. Like I said, I have more time and talent than I do money.
mlynch001
mlynch001
193
879
Dardanelle, AR
I like your 3D printing work, I've gotta get me one of those.
Did you buy the seller's story that someone else sunk it? Seems like a bit of a tall tale to me...
IF you think you have the time, a 3D printer is the bomb! I have made TONS of partsand other stuff with mine. I would not be without a 3D printer.
As far as the story, I think he is being straight up. Another person who knew the machine told me a similar story about it and that the person who drowned it was a family member who was "looking to take over payments". It could have already been damaged, who knows? His loss, My gain.
mlynch001
mlynch001
193
879
Dardanelle, AR
At least you are able to do some stuff yourself, plus you know and admit your limits. Like I said, I have way more tools, talent and time that I do $$$. I just cannot throw that much money at a toy. This thing would not have made a very good parts machine, since all the parts that usually break on a PIONEER had already broke. It was exactly what I was hoping to find. Answered prayers!
mlynch001
mlynch001
193
879
Dardanelle, AR
FINALLY! Got my Cage Chopped. Finished putting everything back in place last week. I like the change. The P1000 always looked “out of proportion” to me, too tall in relation to its length and width. This took about 12 working hours to accomplish and with very common tools. I'm not a welder, but was able to stitch this all back together without a problem. Taking about 4 inches off the height made a huge difference. Still plenty of headroom for us, we are both under 5’11”. Yes, the bed still dumps. I am still working on the windshield since I want to avoid cutting that poly carbonate if possible. I am pretty sure I can make it work with just some minor changes, short of a "Full Windshield Chop". Actual cuts were 3 1/2" from A Post, 4" from B Post and 4 1/2" from C Post. I did not take "step by step pictures" this is foo distracting and time consuming. I do have a "Before" picture, taken last year and an "After" picture just taken a few minutes ago from about the same spot. The difference is very noticeable.
IMG 0458
IMG 1265
IMG 1269
IMG 1195
IMG 1243
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Actually, cutting polycarbonate is a piece of cake, unlike acrylic (Plexiglas) which tends to crack and chip. Polycarbonate can even be cold bent in a brake as one would do with sheet metal. You can use most woodworking tools, table saw, saber saw etc. for cutting. Just use masking tape to prevent scratching.
mlynch001
mlynch001
193
879
Dardanelle, AR
Yes, I have cut PC before. Much more forgiving than Plexiglass or Acrylic. I was figuring if I ever wanted to change windshields and sell this one, that the uncut version would be more appealing to a wider range of buyers. I can always go back and cut it later if I change my mind.
mlynch001
mlynch001
193
879
Dardanelle, AR
I finally got my under seat cooling bilge fan and PID controller installed and working. Another item knocked off the "to do" list. Fan pulls air from below the drivers knees and is controlled by a PID auto controller with a thermocouple sensor under the seat. At a selected and driver adjustable set point, the fan controller starts the fan and draws cool air through the intake duct. Air then enters the fan and flows through ae exhaust duct up and underneath the seat through a plenum and then flows out the back of the plenum and is directed back to the exhaust side of the engine and out from there. I have not tried this in super hot weather, but the temperature seems to be better regulated and less heat comes through the seat bottom. I have the option to add a second fan as needed.
