P700 Need help finding the speedo plug please!
Smoking Joe
Smoking Joe
134
418
Alaska
I put portals on my 700/2 and now I'm trying to install a speedo drd from 12 oclock labs but can't seem to find the speedo plug...I thought I found it but the tabs don't fit in the slots of the plug I got! Looks like it would fit otherwise...attached is a pic I thought would be the correct plug taken from the passenger side just behind the fuel tank. Would appreciate any help on this...@hondatech🤔
Maybe got the wrong part but someone here posted the link and the product description had my model as a plug and play fit!
20210605 162253
caverat
101
193
Montana
The one I bought I just unplugged it off the rear differential and put it in line. Totally screwed up my shift points so I pulled it out
Reactions: Smoking Joe
Smoking Joe
Smoking Joe
134
418
Alaska
Thanks I will look there! Instructions said look at the back of the trans for the plug. And I'm hoping it changes my shift points as right now it's shifting into 2nd at 5mph! With 30% portals and 28s I'm needing -23.7% correction
caverat
101
193
Montana
Thats the same thing I'm running 30% portals and 28 inch tiers mine would hit the rev limiter before it would shift
Smoking Joe
Smoking Joe
134
418
Alaska
Maybe your correction was wrong...plus instead of negative correction? -23.1% after redoing the math...maybe check your impedance mode?
caverat
101
193
Montana
I used the speedo healer and just used there app for all the corrections. when driving normally it shifted fine but when I NASCAR it was when there was a problem. It was shifting at the correct MPH just to high of RPM.
I did get to take a little ride last weekend. Loving the machine with portals done a little later evening rock climbing up in some water falls. The extra articulation and low gearing from the portals make the thing a beast. Thing will crawl 2 MPH and just hooks up like crazy. Just ordered some Fox shocks the stock ones bottom out when coming down and dropping off in a hole.
Smoking Joe
Smoking Joe
134
418
Alaska
Yeaf after riding with the portals and not having to worry about bouncing my skids off every rock on the trail I've definitely thought about getting the fox shocks but man that price tag is hard to justify! If I drop down a steep bank while turning the stockers bottom and i get a slight rub...not sure how some people claim to have 2" lift with 30s and don't rub unless you're just pounding pavement!
Reactions: caverat
Smoking Joe
Smoking Joe
134
418
Alaska
Only complaint about the portals is when in 2wd the back end gets squirrely!
20210529 094717
  • Haha
Reactions: caverat
caverat
101
193
Montana
ya well I just got an email Fox shocks are out of stock until Septembero_Oo_O wish I could charge my customers first then get around to the job 3 months later :mad:
Hope every one was ok in that little oops moment. My wife would probably beat me like a stray dog LOL
osobad
osobad
6,765
59,581
Tampa Bay Florida
They should refund your money Fox are not the only options.
Smoking Joe
Smoking Joe
134
418
Alaska
Yep just a few bruises...I was the only one in the wheeler trying to keep up with my buddy in his p1000 won't make that mistake again!
