P1000 Need help: when changing oil, I filled new oil using the "Check only, no fill" hole
Q
QuietStroller
23
55
Home
Okay, I'm even more of an idiot than I thought. I actually put that qt and half in the sub transmission dipstick hole.....
I guess same thing. I should try to use a siphon of some sort and get the remaining oil out of the sub transmission? And then finish the oil job correctly?
Bighat
Bighat
874
3,735
Gallipolis Ohio
I'm a f***ing idiot!!!!!!!!!! Idk why I thought it was 6 oil and 2 more was for trans...... So it sounds like I have a quart and a half too much. So I need to see if I can pull the plug and drain some out without leaving too much I suppose.... I'll go get a brand new drain pan tomorrow and catch what I drain out and try to reuse
Don't beat yourself up. Their a pain to change the oil in. 3 plugs, messy, spring on the filter. They could of designed them a little more simple. Note. Check your oil level when finished. I've changed my oil several times and it takes bit more than what the manual calls for to read at the top notch on the dip stick. Others say different but I've check mine everytime and it takes more. Yours may, just check it good the way the manual says to check it. And that's just changing the engine oil and filter.
john790
329
1,012
Clinton ohio 44216
Do your self a favor and drop the plug and move on.Dont stick a hose into a blind hole and exspect good results.
