P1000 New 2016 1000-5 Deluxe Owner
npaden
npaden
47
268
Lubbock, Texas
Hahaha love it! 😜
They are same in many ways for sho!
But the 16’ is still more fuc’d up more than other yrs combined 🤣
The Facebook Marketplace listing had it as a 2017 model. I did some basic research beforehand and felt okay about it and did see some of the stuff on the 2016 models but didn't think it mattered. I think the clutch cover and the air intake were both fixed for the 2017 model.
After the negotiations and with it loaded in my trailer we went to do the paperwork and the title says 2016. We discussed the recalls for the 2016 and he wasn't sure whether they were done or not. I think it was just a mistake as his wife did the marketplace listing. Still feel decent about the transaction, just a bit more to sort through on the recalls.
scttwlsn45
scttwlsn45
64
357
Farmington, WV
Will be the perfect spot to put a 20” LED strip to see behind me.
Welcome from WV. If I could make a suggestion get the reverse light kit with two lights from the club store and the work light harness. I don’t think you’ll get a light bar as bright being it has a bunch of combination spot/flood leds packed into each light
906UP
906UP
14,210
134,619
da Yoop
I think you did well, looks like a clean rig. After the updates are done there's really no difference to the newer models
npaden
npaden
47
268
Lubbock, Texas
Too late. I bought the NiLight kit with the 52" curved for the front and a 20" straight for the back plus 4 little 4" pods. LED lights are WAY cheaper than the last time I bought some. It was $134 for all of them with 2 wiring harnesses.
I didn't really think I needed the extra 4" pods but I think I am going to put 2 on the sides on the 1000-5 and then possibly put the other 2 as back up lights on my Rzr 570. It has a good light bar for the front but not the back. To be honest I hadn't ever really thought I needed one for the back but with the dump bed maybe I might.
Haven't decided on the dual battery setup yet but leaning that way. I've always just kept a jump starter pack and a air compressor on my machines and didn't even think of a dual battery before reading on here. Of course there really isn't a place to put a dual battery on my Rzr anyway.
Rayger143
Rayger143
3,065
26,856
Winfield, BC Canada
Like my side cubes
scttwlsn45
scttwlsn45
64
357
Farmington, WV
Haven't decided on the dual battery setup yet but leaning that way. I've always just kept a jump starter pack and an air compressor on my machines and didn't even think of a dual battery before reading on here. Of course there really isn't a place to put a dual battery on my Rzr anyway.
When you go to install I think the club store has a diy backup light pigtail. It plugs into a provision Honda put in for a backup siren. This makes the lights come on automatically whenever the machine is in reverse. Which is super nice, except for the times you don’t want them on or you want them on a toggle. That is where the work light harness comes into play. It pits it on a switch where you can run them on auto with reverse, completely off or on regardless of what mode the transmission is in. Good looking machine, I have a three with the same hard rear panel
115,117
They were in the 18’s
16&17’s had those issues.
You usually know if u had them done. So Id just make sure as soon as you can make the time to do so.
tjoreo
tjoreo
1,024
1,966
Southern Idaho
There should be vehicle sticker above the right rear wheel attached to the frame that will tell the year of the machine. One trouble I had with my 2018 was the fan not coming on and over heating. I had it reflashed as per the service campaign and haven't had trouble since. According to the paper work it just effects 2017-2019 but it might be something to check. Looks like you got a great deal and wonderful machine. Enjoy.
npaden
npaden
47
268
Lubbock, Texas
Trying to decide if I should just keep adding to this thread or start a new one for all the add ons.
Figured out that I don’t have the updated clutch housing and am working on that. I did post a different thread for it. Got the 20” light bar put in the back.
IMG 9241
Got the strut replaced so the bed actually opens thanks to the thread by
Dirtstiffs-1000
And got the HillyBilly brake installed tonight. I need it to load in my trailer because the slop in the gears lets it rock too far backwards and it won’t fit. This should lock it in place perfectly.
IMG 9250
Think I’m taking it in to get the recalls done and the improved clutch housing put in so probably won’t have many updates for a while.
Rayger143
Rayger143
3,065
26,856
Winfield, BC Canada
Dirtstiffs-1000
Keep this thread going. You can change the title
Reactions: npaden and ChadD
npaden
npaden
47
268
Lubbock, Texas
I was inspired by getting new LED light bars for the new to me P1K5 so I decided to add them to my tractor.
The work lights that were on there weren’t much better than candles so it was quite the upgrade. Used it tonight and couldn’t even tell when I turned the headlights on the front light bar was so bright.
Here’s an older picture of it with the old lights.
IMG 0756
Pictures from tonight with the new lights installed. Took the pictures just before sunset so you can actually see the lights. I added some flood lights on the side that allow me to see beside it which is nice.
39” light bar on front. 4” flood pod on the side.
IMG 9360
You can see the angle of the 4” flood pod. I was originally thinking of angling it directly to the side but the way the bracket was it angled it toward the front and I think it is better this way. There is a very small gap between the side and back but just a tiny one.
IMG 9362
6.5” pods with spot and flood combo on the back. Very bright.
IMG 9364
Overall very happy with how they turned out. Not sure why I haven’t done this years ago but glad I bought the P1K5 so it made me think about it. I’m adding some more lights to my RZR too.
The dealer is done with the new clutch housing and new clutch and I’ll be picking it up next Tuesday so hopefully I’ll start making progress on it soon.
npaden
npaden
47
268
Lubbock, Texas
Got the machine back today.
Recalls were:
New muffler guard.
IMG 9391
New gas pedal:
IMG 9392
New throttle body:
And new steering knuckle:
IMG 9394
New clutch and housing was a $1,615 hit since the service campaign has been over for more than 3 years now. They did save the old clutch to show me and it did seem pretty burnt.
Drove it around a bit when I got it home and not sure I noticed a big difference. That said I only drove it about a mile before taking it in so not much to measure it against.
I’ll try to get the 2nd battery and lights and other fun stuff put in this weekend.
npaden
npaden
47
268
Lubbock, Texas
Went ahead and replaced the fender flare with one I bought online. Found one for just $25 online but shipping was $44. Still cheaper than buying local.
IMG 9395
IMG 9396
Going to have to drill some holes to get the mud flap back on and the very front hole isn’t lining up so I think I’m going to have to drill that one too.
Still a big improvement over the broken duct tapped version that was on it.
115,117
There is a marked difference in shifting and more smoothness. Also can run in high at lower speeds without issues.
If they where burnt before and you only drove it a mile before, yeah hard to actually notice.
Good thing you got it done tho!
Reactions: ChadD
O
ob1jeeper
98
282
Arizona
A bit late to the party, but welcome from AZ. I have the identical 2016 unit, and I believe you will come to love it... ;)
Reactions: ChadD and npaden
