P500 New p5 battery drain.
V
viking1983
11
Hello. I have had my P5 for 2 months and I have an on going battery drain. I found out this week that it has a GPS box attached to the battery for powersports protection. I have a free 12 month subscription. Could this be the reason by battery drains? Should I just unhook it?
906UP
906UP
13,200
123,379
da Yoop
Yes and yes. Sounds like some sort of tracking device, did the dealer sell you on this? Stuff like that is a useless money maker for sh1tty dealers
DRZRon1
DRZRon1
893
2,910
unhook it should resolve it or keep it on a tender full time
do u have a wireless winch control by chance
V
viking1983
11
Ok thanks. I was never told it was attached. I got an email from powersports protection saying my battery was low and after digging into how and why the email I was told it's a 12 month free promotion then u pay. I will unhook.
DRZRon1
DRZRon1
893
2,910
$13 a month eventually to drain your battery and tell you it’s low - great.
did dealer add this to machine and charge you for it?
V
viking1983
11
It was added but I was never told. I received a text from powersports protection telling me my battery voltage was11.6. I called dealer and found out I received a 12 month promotion and that the GPS box was attached to my battery. I removed it this morning.
DRZRon1
DRZRon1
893
2,910
none of my business but my advice is to have insurance, don't leave keys in it, keep it locked up if ya can, sucks if someone steals it, but I cant imagine its more than $150 a year for insurance.....
a savvy thief will strap that gps box to a dog or another vehicle - lol........
Glank
Glank
100
340
Hello all, as far as battery drain, my battery has died several times over the winter. I did have this issue last winter, but I did install a second battery last spring and yes, that included an isolator. I can't figure out why the main battery is getting drained, besides lack of use which is my fault. I'm looking into a trickle charger, but wondering if anyone has recommendations on a solar trickle charger.
DRZRon1
DRZRon1
893
2,910
Need pics, may be asking for a friend
-need details, where stored, for how long between starts, accessories that may be a drain, modifications, how cold when stored ,etc…….
For solar - my hunch is any harbor freight or similar cheapo system will work
160,066
You posted this in the P500 threads so a lot of the P1000 guys aren't going to see it. You're on the right track though, lack of use will do it especially in the cold. Don't know anything about a solar charger but I have a trickle charger on mine whenever it's not in use.
Glank
Glank
100
340
Thanks for letting me know I’m on the wrong thread. I guess my search wasn’t specific to P1K5. 🤣
OlYeller15
OlYeller15
192
1,170
I have one I got from amazon. It works very good.
CE65C9CA 8808 4C23 84E6 BA0757469483
Scoop
Scoop
4,278
16,035
  3. Talon R LV
You live in Saline. We don't get sun here half the damn year.
I permanently installed this NOCO 2A direct mount onboard charger on the machine, and added the AC Port plug. That way, all you have to do is push a standard extension cord in it instead of dealing with removing hoods, clipping clips on terminals, etc.
Here is my install: P1000 - Scoop's 2021 P1K5 Deluxe Phantom Camo Build
Glank
Glank
100
340
Thanks. My buddy recommended the same trickle charger. I checked the battery In December and January and it was dead. So, the battery lasts less than a month. I have all accessories on the second battery. I was looking into this solar charger and I can mount it in a window next to the machine. I like your install.
8A9AF0B2 17F2 43CE 8923 018709E69C7F
Scoop
Scoop
4,278
16,035
  3. Talon R LV
I can let mine sit for far longer than a month without being on the charger and it's fine. While a trickle charger or solar panel would keep the battery level up, it's only a Band-Aid on a bigger problem. You've either got an issue with the battery itself or something causing the drain. Could be shorted wire, could be a short inside of something, or even something being left on that you're not aware of.
Glank
Glank
100
340
I need to get my dual volt meter installed so I can tell if the batteries are playing nice. I recharged the system again and plan to check both batteries with a volt meter periodically. Here’s a pic, maybe you can tell where the short is. 🤣🤣
4774D9C7 1B12 433E 8243 C8D8871FE866
906UP
906UP
13,200
123,379
da Yoop
Both my buggies can sit for months, sometimes 4 or 5 months since we're buried in snow UP here, and never go dead. My P5 is going on 6 years old and is still on the original battery, I have had it on a charger exactly 0 times. A trickle charger isn't a bad idea but as Scoop said, you're not really fixing the problem.
Buggyman
Buggyman
35,577
302,584
ne. ohio
same here
