P1000 New shoes
N
NutriAz
12
31
Nutrioso Arizona
  1. Looking to buy
I'm going to order a wheel / tire set up off Amazon for my 2023 1K5 going with the 28X10X14 tusk terrabite and tusk wheels. Will most likely do the 1 inch rear spacers from RB3 because they are here in town. I am given 2 options for offset. I was going with the 4X3 but could also do the 5X2 to keep a more stock profile. Any thoughts on the 5X2?
Thanks
107,306
for my 2023 P1K5
Fixed it for ya.
Also, no pics form you yet of your rig. Now your getting new shoes! C’mon man!
Post em up! Might as well do a before and after pics. Your making this harder than it needs to be for sho! 🥳
POIDH
107,306
Yes same size all 1 corners
Best thing you will ever do next to post#5
If u havent bought your wheels and tires, I would suggest 15” lot easier to find other tires for it especially if u go LT Down the line and they look better imo.
But its all up to you.
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
Check the actual offset if it is listed in the description. Most wheel manufacturers use MM offset dimensions, and a lot of wheels advertised as 5+2 are closer to 4+3 in reality. For trails that enforce width restrictions you may find that you are wider than what is permitted with 4+3s and spacers.
toddvdh
toddvdh
1,072
7,063
Green Bay, WI
The forum code. It's always about the code. Can't get it outta my mind. 🧐
IMG 0895
  • Haha
Reactions: Backwoods
PJon
PJon
776
3,124
Arizona
Thanks
I run 5x2 on mine with a 1” spacer on the back. If you haven’t ordered the wheels and tires yet, I’d recommend going with 15”. They’ll give you more options later. Especially if you want more lift later with better shock/spring combo’s or SATV A-arms. If you’re getting into higher elevations, be careful regarding how large you go on tire diameters. You’re going to have less power and don’t want to be stalling out going up ledges.
