P1000 New shoes
N
NutriAz
16
61
Nutrioso Arizona
  1. Looking to buy
I'm going to order a wheel / tire set up off Amazon for my 2023 1K5 going with the 28X10X14 tusk terrabite and tusk wheels. Will most likely do the 1 inch rear spacers from RB3 because they are here in town. I am given 2 options for offset. I was going with the 4X3 but could also do the 5X2 to keep a more stock profile. Any thoughts on the 5X2?
Thanks
108,185
for my 2023 P1K5
Fixed it for ya.
Also, no pics form you yet of your rig. Now your getting new shoes! C’mon man!
Post em up! Might as well do a before and after pics. Your making this harder than it needs to be for sho! 🥳
POIDH
108,185
Yes same size all 1 corners
Best thing you will ever do next to post#5
If u havent bought your wheels and tires, I would suggest 15” lot easier to find other tires for it especially if u go LT Down the line and they look better imo.
But its all up to you.
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
Check the actual offset if it is listed in the description. Most wheel manufacturers use MM offset dimensions, and a lot of wheels advertised as 5+2 are closer to 4+3 in reality. For trails that enforce width restrictions you may find that you are wider than what is permitted with 4+3s and spacers.
toddvdh
toddvdh
1,078
7,117
Green Bay, WI
The forum code. It's always about the code. Can't get it outta my mind. 🧐
IMG 0895
PJon
PJon
782
3,161
Arizona
Thanks
I run 5x2 on mine with a 1” spacer on the back. If you haven’t ordered the wheels and tires yet, I’d recommend going with 15”. They’ll give you more options later. Especially if you want more lift later with better shock/spring combo’s or SATV A-arms. If you’re getting into higher elevations, be careful regarding how large you go on tire diameters. You’re going to have less power and don’t want to be stalling out going up ledges.
540RA
540RA
Not So Well-Known Member
187
1,790
  1. 1000 6 Crew
Fixed it for ya.
POIDH
I'll cover for OP by hijacking the thread with a teaser pic. Same size and brand wheel/tire combo for the short bus. The rims are 5+2
Haven't gotten the spacers yet because the suppliers I've checked with so far will not ship to a PO box.
I don't care if it takes more work in the long run, I'll mount them today because I'm impatient... I'll add the spacers later.
IMG 20240523 155302089 HDR
108,185
Nice wheels.
Yeah most wont ship to a PO Box
Do u have a neighbor you can have them shipped to?
Also, have u tried or spacer vender here on the forum @RB3offroad
540RA
540RA
187
1,790
  1. 1000 6 Crew
Nice wheels.
I'll give RB3 a call later. I'm guessing that most spacer sellers ship via Fed-Ex. The tires were shipped through Fed-Ex, so I'll quit being stubborn and order some spacers. I use Pay-Pal (with a PO Box address) on ebay...and that is why i was having the shipping issue.
PJon
PJon
782
3,161
Arizona
I'll give RB3 a call later. I'm guessing that most spacer sellers ship via Fed-Ex. The tires were shipped through Fed-Ex, so I'll quit being stubborn and order some spacers. I use Pay-Pal (with a PO Box address) on ebay...and that is where i was having the shipping issue.
Get the RB3 spacers.theirs are just enough thicker that you don’t end up having to grind off the ends of your original wheel studs and lug nuts.
