New wheels for Talon X 14”or 15”?
Elkhunter
Elkhunter
345
453
Minnesota
I’m going to get some 30x10 tires for my Talon X. I ride some rough rocky trails in AZ. I’m going with STI HD-9. They have 14” wheels that have been tested and work on a talon. I have read that the 14” with a little more sidewall will absorb a little more than the 15” tires. I know I will lose a little of the cornering ability with the 14 “ but I’m not that aggressive of a driver. What would you purchase?
P
packman10
N. Illinois
  1. Talon X4
Why not both? I'm putting 15"s on front, an 14"s in the rear. Tires are 30x10 kahuna's.
Elkhunter
Elkhunter
345
453
Minnesota
And the reason for you running 2 different sizes?
208,029
Yep, I hate sidewall pinches!
P
packman10
N. Illinois
  1. Talon X4
Same reason the op asked the original question. Same reason talon comes with different size tires. Same reason most sport quads come this way. Less sidewall flex up.front for handling, more give in the rear for comfort.
  • Haha
Reactions: TripleB
208,029
Been there done that, if you ride the rocks, you need a wider front tire to spread the impact out over a larger area, like I said been there done that, your coin, spend it as you see fit?
Reactions: Mudwing
P
packman10
N. Illinois
  1. Talon X4
The OP seemed slightly concerned about handling, and also concerned about give over rocks, hence my suggestion. I ride in rocky soil (midwest) so it works for me. The real beauty is you get to try it both ways, if one suits you better than the other, well, you already need a 5th spare, so what's one more in your favorite flavor!
PaulF
PaulF
1,462
4,810
From your description, the 14's should suite you better. The X needs all the help it can get on rough terrain and pinch flats are all to common with shorter sidewalls.
With 14's, you can run 30X10X14's pretty low and if you find yourself some days in areas with smoother terrain and can drive a little more aggressively that day, you can always air up a little for less sidewall flex.
Elkhunter
Elkhunter
345
453
Minnesota
There are also a lot of 30s that only come in 14” unless you jump up to 32s there is a better selection in 15s. I’ve been looking at Maxxis Rampage and the 30s only come in 14s.
Reactions: BlackCSVT
TerryH
TerryH
664
2,241
Springdale, Ar
I've run 14" wheels on my X since new. Have worked out great. Just changed from Racelines to the STI HD9 beadlocks. Have 32x10/14 Roxxzilla's on them. Love the combination.
50867065517 4355a4aecc b
BlackCSVT
BlackCSVT
22
27
Vail, AZ
  1. Talon X4 LV
That’s the tire and wheel combo I’m 99% sure I’m going to get. Best price (with good service) that I’ve found is PlanetSXS, $1300 otd
TerryH
TerryH
664
2,241
Springdale, Ar
I got ours from PlanetSXS also. It was a great experience all around.
Elkhunter
Elkhunter
345
453
Minnesota
How’s the clearance between the calibers and the rim? Do you think there would be a problem with rocks getting wedged between the rim and rotors-caliper ? That’s the only thing that concerns me about the 14s. Ride some in the rocky hills in AZ
Reactions: Isaiah
5,096
22,920
@Lil_Steve was able to do this with a 15" rim so it depends on yer luck and rock size - :oops:
TerryH
TerryH
664
2,241
Springdale, Ar
We ride in NW Arkansas which is nothing but one giant rock pile. Not a single issue for us at all.
34,174
You got any pictures of that pretty machine With mud on it Terry???😍
Reactions: Blownzuki
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
D5FC0142 895E 43E7 91F3 D933FEE23CB3
14’s for tire selection.
I’m running them on my X4 with portals C319FB26 03F2 4ACF 8736 D611D00175AD
Reactions: Mudwing and TerryH
