P700 No power on startup - getting worse and worse!
RFX
7
16
Wellington
Hello you wonderful fountains of knowledge,
Got a 2019 Pioneer 700 that is severely misbehaving! It’s taking longer and longer on startup to get warmed up enough to drive.
I’ve owned it for just under a year, it had the clutch replaced by a Honda dealer right before I bought it, and is used on a fairly hilly farm. I had it serviced in March by another Honda dealer as it was starting to lose power on startup. They thought the oil was low and replaced the oil, filter, etc. it worked fine for a couple of months until recently - now it’s taking over 10 mins of idle before it can drive up any (mild) hill. If I try to drive it before 10 mins it will rev but not move.
I’ve replaced the oil and filter this week - the oil is the correct level - but made no difference in the performance.
Used to just jump straight in and power around the farm. Super frustrating that it‘s now behaving like this!
Anyone got any ideas how to troubleshoot this issue?
Many thanks,
Jon in NZ
Reactions: DG Rider and Farmer
1950Willys
1950Willys
71
151
Arkansas
The 700's should be just over full a little, Also make sure your checking the oil as specified in owners manual.
Reactions: Robobrainiac
JenElio
JenElio
63,960
600,487
Loxahatchee, florida
Many thanks,
Jon in NZ
I'm not too familiar with the 700s but I would start checking the basics first. Oil, fuel, spark plug(s), air filter(s).......
Good luck 👍
Keep us posted
104,971
What all those guys said! But I'll emphasize to check the filter!
Welcome from Michigan
We need some proof of this rig! Kind of a thing here ya know. We didn't get this fountain of knowledge by using our Imagination ;)
PICS OR IT DIDNT HAPPEN!
208,011
The Surieff has issued a warrant!
5,019
22,397
I don't want to freak you out and I'm pretty new to SxSs but it seems to me that some 700's were killing their camshafts. I don't remember much because I'm more focused on the Pioneer 1000s and Talons (similar engines) but it might give you something to search here.
41,700
Many thanks,
Jon in NZ
How many miles? What temps are we talking here? What weight of oil? How are you checking the oil?
RFX
7
16
Wellington
Heya, our early Spring temp here is around 10-16 deg Celsius (50-60 deg F). The oil I just used is 5W40 Fully Synthetic (dealer recommended this viscosity rather than 10W30/40). Checking oil after running the engine for a couple of mins, engine off, dipstick out, clean dipstick, place dipstick back in housing (don’t screw it in), take reading. I have filled the oil to the top of the top flat part (again, dealer recommended filling oil to this part rather than the lower flat part. Hope this makes sense and thanks for your help!
Jon
41,700
Jon
Sounds like you're pretty close to what the factory recommends as far as oil level check. I usually wait 2-3 minutes after shut off and put the low side of the oil "ramp" at the full mark. You might be a bit higher, and we have heard of them being too overfilled causing shifting issues.
So just to be sure, I might drain a touch (probably just pull the filter cover or something) and see if it helps. Probably won't, but...
Unless that's where you've always ran it? In that case, it's probably time to start checking oil pressures at the test ports.
Farmer
Farmer
2,851
16,389
Southern MO
@RFX My cam did not improve when it warmed up. When the lobes are gone they're gone. Yeah it's possible for a cam to go bad for multiple reasons but it doesn't sound like your problem. I also think that the cam thing was an early model issue. "Should" be solved by now.
The trans in these things are bullet proof but I'd start thinking about it. I'm no tech.... but lack of power caused by air, oil and fuel shouldn't change after ten minutes unless it's a trans or brain box thing.
5,019
22,397
The trans in these things are bullet proof but I'd start thinking about it. I'm no tech.... but air, oil and fuel shouldn't change after ten minutes unless it's a trans or brain box thing.
Thanks, Farmer. 👍
ElmerFudd
ElmerFudd
54
91
Friend of mine got oil change kit for his Pioneer 1000. Noticed the new transmission filter was built wrong. Different than the one he took out. The ends of the filter are different and it was built backwards. Rubber on wrong end. He had another one and I looked at it. It was built wrong. Might check that.
Robobrainiac
Robobrainiac
2,455
8,527
Just out of curiosity, to clarify your issue,
When attempting to climb before its "warmed up" does the machine stop and slightly rev above idle without movement: as if it was nosed against a wall. Or does it rev up almost as if it is in neutral?
What is your opinion on "warmed up"; are you referring to the coolant temperature displayed on the dash or the engine/transmission being warm to the touch by hand?
RFX
7
16
Wellington
Hi, so I can start the machine as normal, put it in drive, then hit the gas - it may drive forward as normal for a couple of metres then completely stop. If I keep my foot on the gas it will rev as if it’s driving but will not move forward.
I’ll give it a couple of minutes in neutral then pop it into drive and hit the gas again. It may drive forward for 10-15m then stop as above. Repeat the process of a few minutes in neutral then drive a bit more, etc! Used it a couple of days ago and it took about 8 of the above to get it going properly.
Once going properly it will run all day as normal!
So my definition of ‘warmed up’ is when it’s running properly. I haven’t checked the dash displays or touched the engine/trans by hand.
Thanks for you help, it’s most appreciated! : )
RFX
7
16
Wellington
Had a look at the air filter today - there was one clip unlocked and there’s a couple of cracks in the air filter plastic housing box. Not sure if it’s standard or aftermarket but mine has a snorkel terminating under the hood hatch - it’s just a perforated metal cylinder with solid end, pushed into the flexible ducting.
btw - my SXS is green and missing bits because it was recently stolen by some absolute bastard, then recovered…
82BFEF2C 5FCB 4F1D 9A4E 28FB60BCF57C
104,971
Dam dude! Dont u have insurance?
I would assume Wellington is somewhere in Canada seeing your sighting Kilometers ?
RFX
7
16
Wellington
No insurance. It’s just used on farm so didn’t think I would need insurance! Wellington, New Zealand. Thieves tried to de-Hondaify it - removed front badges, cut out the Honda logo on the rear tailgate, removed seats (installed s***ty bucket seats), ‘rewired’ some of it, tail lights missing, Kawasaki green where it was red, etc etc…
