Offset - MSA vs. Stock
sek-hunter
sek-hunter
306
574
I am looking at the MSA M25 Rocker. It comes in two different offsets for the Pioneer; +10 and -47. The wheels are 14x7s.
My question is this - Will the +10 offset stick out farther than the stock wheels?
I don't know what the offset is on the stock wheels.
Seems like the -47 may stick out too far.
Any picks with wheels with similar offsets would be greatly appreciated.
sek-hunter
sek-hunter
306
574
If I am thinking about this correctly, the +10 should move all 4 wheels outer edge out about an inch? That would make the track 2 inches wider front and rear?????
Sound about right?
63,507
Check out there page that explains it all.
http://cocomponents.com/dealer/blog/whe ... explained/
Ya, -47 is not for the Pioneer. You will need to go with the +10. And , Yes it will be wider then factory adding around 3 inches in width on the front and 2.5 on the rear.
MSA 14x7 - (+10) or 3.89x3.11 offset.
Factory wheels are:
Front 12x6 - 4.5x1.5 offset
Rear 12x7.5 - 6x1.5 offset
Your not going to find a aftermarket wheel to match factory specs as there too unique.
sek-hunter
sek-hunter
306
574
I want the track to be slightly wider. I was thinking that the 10 would give mean extra inch or so of width at each wheel but the -47 would make it way too wide.
Hondasxs, didn't you have some 14 inch MSA Wheels? What was the backspacing and width of those?
sek-hunter
sek-hunter
306
574
20113a6cf4771ee60b4bd23de3bcfb1f
Found this pic on the www. Do you think this is the positive 10 version or the negative 47?
63,507
Hard to tell..
The front view one you posted looks extra wide.
These are the same build and look like +10
63,507
Can't be -47.
Look at the caliper. It's still in the wheel. There is only 1.63" available on a -47.
sek-hunter
sek-hunter
306
574
Did you like the stance of yours pretty good with the MSA's? Was the front and rear track pretty close? What about mud in the cab on muddy rides?
63,507
It's only noticeableb if I show it to you. But I think the front sticks out more then the rear. Maybe .25 inch. Not much. It's not noticeable otherwise. And maybe it's just me. I think it's because of the weird factory set.
Mud flying everywhere.. oh Ya. Where 4-wheeling. You will want fender flairs.
63,507
I liked the MSA wheels I had. Just didn't like the 14 inch and sold them with my Rincon. Thinking of getting another set of 12's.
