P700m4 Oil usage
Dobie
10
5
Canada
I am going through some oil. about 1-11/2 quarts per tank of gas. no visable leaks, no blue smoke exhaust pipe has dry black carbon inside, checked my valves. Not sure what else to look at. any ideas?
41,939
That's a lot if oil to be loosing internally without smoking. Impossible, really.
Have you checked the breather hose to the air box or the air box itself?
What year and how many miles/hours?
Reactions: swsebek
Dobie
10
5
Canada
2014 and about 14,000KM or 8,000 miles. I had the air box out on the weekend snorkeling it to the front trying to cut down on the noise. nothing looked abnormal, maybey a little oil film in the box. when you see breather hose what are you refering to?
Reactions: DG Rider
41,939
The one from the crankcase to the side of the air box.
If you are 100 percent certain there are no leaks then it may be time to do a leakdown test. I'm assuming you aren't seeing smoke out the exhaust.
I took a 2014 over 8000 miles ( at the time I sold it ) with zero oil usage, but that really depends on how it was treated.
Reactions: Mudwing
Dobie
10
5
Canada
I do think I take pretty good care of it. I do oil changes on a reg. schedule. I keep it in a heated garage.
Theres no smoke from the exhaust. I did not check that hose when I had it out. It is connected and in good shape. Im not sure what a leak down test is but i thik I remember an article on it somewhere.
Reactions: DG Rider
Dobie
10
5
Canada
Did a quick read on the leak down test. Ill try that to be safe.
Reactions: DG Rider
41,939
A leak down test pressurizes the combustion chamber with compressed air and measures the amount of air that escapes. It's like a better compression test.
Reactions: Mudwing
Dobie
10
5
Canada
I agree,Impossible!
You would see it dripping somewhere..
YA. I gave it a good look several times.I had all the plastic off around the engin this weekend and dont see any leaks.
Vato
Vato
180
159
Mine had the disappearing oil delimea too at about 6800 miles....think original owner might have over heated it. I'm a good mechanic and I checked everything and it ran like a top but never did figure it out. Rebuilt the top end with new cylinder, piston.....everything....problem solved. Still have the original parts and I had the Machine Shop check everything and they couldn't figure out why it was using oil either cuz everything was was within the published tolerances. New parts have an amazing way of correcting problems! LOL. If Honda had not warrantied the parts, I would have bored the original cylinder with new piston/rings which I believe would have solved the problem.
Dobie
10
5
Canada
Thanks Vato. I think were on the same page. Im going to bring it in and have it rebuilt. Reality is its burning that oil somewhere.
allgm1
allgm1
1,049
1,484
New Hampshire
I didn't see where you said you checked the spark plug to see what it looked like. I would think if its burning that much oil you plug would be showing signs of it.
Dobie
10
5
Canada
No I have not got there yet. Hoping to tear the plastic off this week to make things easier to get at and do a compression test before I take it in.
Vato
Vato
180
159
My plugs did not show signs of excessive oil usage, no leaks maybe a little bit of oil in engine vent It was a weird situation and oil usage was not as dramatic as yours. A a new top end solved my mysterious oil disappearance. Keep us posted this kind of stuff is fascinating especially to have another 700 experiencing excessive oil use like mine did...hmmm.
Reactions: Mudwing
Ryan33
New York
Have a 2019 pioneer 700. Started losing oil after a couple hundred miles. Only noticed because it was shifting hard and then wouldn’t shift. Brought it to dealer while under warranty and they couldn’t figure anything out. Brought it home eventually lost oil again. Brought it back to dealer (2 months after warrant was up), this time they actually looked at the piston and said they could see scoring and told me my air filter was dirty. Honda won’t warranty the problem, blaming me for lack of maintenance because of the dirty air filter. Any suggestions, can a dirty air filter cause oil loss?
Mudwing
Mudwing
36,959
306,563
The Mud holes
I wouldn’t think so but suppose it’s possible. I would be checking the intake boot clamps etc also. If you were able to tackle this repair, we’re here to help. Is there blue smoke in the exhaust? Or soot in the spark arrester? Oh and welcome to the club. 😎
Reactions: Backwoods
Ryan33
New York
No blue smoke, no oil underneath it where it’s parked. Not sure bout the soot in the spark arrester.I know the basics but not a mechanic. Thanks
Reactions: Mudwing
Randy Walker
Gilbert Louisiana
I have a 2019 Honda 700 side by side that the oil is disappearing in also. No smoke and no leaks Oil has been changed on regular basis and I am not rough on it at all. Anyone know what the problem could be
Mnjr
20
39
Mammoth Spring, Arkansas
I'm having the same problem. Original owner with 4700 miles on a 2016. Wrote to Honda a year ago. Never heard anything back. How did you get assistance?
