P1000 P1000 broken engine mounting bolts
bumperm
bumperm
1,851
6,658
Gardnerville, NV
So, here is a picture of my baby on the operating room floor:
And here's a pic of the failed surgery:
The lighter color in the center of the bolts are actually the "easyout" that broke on BOTH of the bolts. Cheap crap. Anyone have any suggestions of where I can get a good quality/STRONG easyout?
I'm guess I'm going to have to re-drill and this time, now that I have read @snuffnwhisky comment, drill all the way through and re-soak with penetrating oil. But will that drain the oil? What's on the other side of the broken bolt?
Or I'm going to have to learn how to weld or find someone who can to do the nut trick for me.
As @Smitty335 said, don't even try to drill for another EZ-out attempt. That metal is hardened steel and you'll make a mess of things.
Welding a nut on is really the best solution at this point. Soak them real good, for now, with penetrating oil.
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,154
Cullman, AL
  2. Other Brand
Its a blind hole. There will be air space behind the bolt when breaking through. But the easyouts are really hard and really hard to get out if broken. I would weld a nut to them.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I like to weld a flat washer on first then weld a nut to the washer I think it is easier to get good penetration into the twisted off bolt welding a washer fast rather than trying to weld inside of a small nut.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
Exhibit A in why I haven't used an "easy" out in years, and will probably never use one again. F those things. Easy my ass.
I haven't either @P1K5Dave , but that said, using them is okay, IF done right. firstly, I use a left hand twist drill bit (it's handy to have a set), as there's a good chance the recalcitrant threaded shaft will back out while drilling. I have a lathe, so if the break is recessed, I can make an insert sleeve to keep the drill perfectly centered (it's the pits to have a drill go off center). I know not to apply too much torque and break the dang brittle EZ-out.
EZ-outs have their place, but you gotta know when to stop and go for welding a nut on.
RingMaster
RingMaster
176
710
Little Rock, Arkansas
Wow, this is a possible failure point I was unaware of. My '18 with 14K miles is going to get an inspection.
When you get a chance, please verify the bolt size (and length.) I'd like to get a set on order before I even look at it.
Sorry it took a while to reply to you P1K5Dave. Here is a pic of the Honda part number 95701-1902500 it's 25mm long and 10 mm wide. I found these M10-1.25 metric 8.8 at Home Depot that match threads exactly. I have no idea if the strength/grade is good enough or not... probably not.
20230716 122147
RingMaster
RingMaster
176
710
Well, we had about 5 guys lose a battle with these stupid broken bolts yesterday. We couldn't get a drill to bite through the broken bolt extractors so we resorted to trying the welding a nut to the broken bolt trick, and failed on that too. The weld wouldn't hold with a wire welder. After a couple of hours we gave up for the day and took our ice chests to the lake.
I'm not sure what my next move is now. I'll have to wait for some type of motivation to try it again.
Thanks for you guys help in any case.
RingMaster
RingMaster
176
710
Hess makes a brace like this for Talons, I don't see why it wouldn't fit pioneers as well.
I was wondering about that too. But I would still have to get the two broken bolts out in order to bolt on the brace. Unless I just used the single bolt at the top of the brace and just left the bottom two bolts completely off. But I'm afraid that single bolt would break the engine case at some point.
I meant for future prevention. I wouldn't run without those two bolts, its just gonna break something else
the Hess Mount would fit the engine, but it won’t fit the bracket that mounts to the frame without some custom fabrication. So my thought is that if I was doing custom fabrication, it was a lot easier to modify the factory pioneer mount.
Let’s go ride stony lonesome after we fix this motor mount. It’s a local park around here. It won’t take but a couple hours to fix it. Show up on Friday afternoon and we’ll fix it that evening then ride Saturday and you can return Sunday.
NTCPrezJB
NTCPrezJB
President of #NTC
101,773
909,084
Canton, OH
Can’t beat that offer
Nomojic
5,065
22,726
DOOD, jump right on this offer, right NOW - no excuses, load up, drive - who doesn't like a road trip and U get yer buggy fixed to boot. 😍 (nomotho)
