P500 P500 burning oil and smoking
BThompson
BThompson
23
70
Potlatch Idaho
Hey everyone. I have a 2018 p500 with less than 1000 miles on it (somewhere in the 600 mile range I think) that started smoking really badly. Checked the oil and it was very low. Luckily I carry extra with me so I topped it off and got towed back. No knock in the engine that I can hear but just keeps filling my back yard with blue smoke so it has been parked until I can figure out what to do next. I had just changed the oil and I change the air filter before almost every trip but I had been riding in some very dusty conditions and I am worried that some fine dust got into the engine. Any expertise on what kind of damage I am looking at would be helpful. Thanks
DRZRon1
DRZRon1
852
2,744
suggestion
look at intake, throttle body for loose connections and dust on the intake tract
compression test
how many times u change oil and filter on a 600 mile machine
Are you oiling the filters before installing?
BThompson
BThompson
23
70
Potlatch Idaho
Yes I have been cleaning them and oiling them. I have like 6 different filters that I rotate through
But there is a chance that maybe I didn't oil enough. I was coating the whole filter and it almost seemed like it was too much. Are you supposed to oil inside and outside the filter? Because I think I may have been oiling just the outside
Jerryg
Jerryg
10,668
86,291
NEPA
Check for dirt in the intake/throttle body and intake port. If you find dirt beyond the air filter, you will need new rings.
BThompson
BThompson
23
70
Potlatch Idaho
suggestion
compression test
I had only changed it once myself. I bought it used and only put around 100 miles on it. I thought about doing a compression test but I decided that I would let a shop go through it because I don't trust myself
C2Corvette1
C2Corvette1
92
434
Texas
While you are at it (ring replacement and cylinder bore and piston inspection) be sure to check valves and guides as they can also get rapid wear due to dust injestion.
DRZRon1
DRZRon1
852
2,744
need pics of machine - this smells real sketchy without pics
has to be more to the story - 6 filters you rotate - I get it, its dusty, so what, where did the dirt actually get in, why 6 filters? need pics of filter on machine when it started blowing smoke
if you oiled the outside completely, imo, perfectly fine, filters actually filter better the dirtier they get - then its a point of not enough air
what you clean filters with? im in no way a mechanic, but end up fixing lotsa machines for friends, amazes me how many air boxes I open up and the air filter foam is disintegrated from god only knows what cleaner
Happy Easter!!!!
Jerryg
Jerryg
10,668
86,291
NEPA
Generally I have found the valve guides to make it through the first set of rings but, def check them. You don't want to go in twice.
Reactions: Backwoods
BThompson
BThompson
23
70
Potlatch Idaho
Happy Easter!!!!
I bought a pack of 6 filters that I would use to change every time they got dirty enough that I thought they needed changing. I used a UNI filter cleaning kit. I don't have pics of when it happened. It happed last fall during hunting season and it has been parked until then. Just now getting the time and money to dig into it. It may be possible that there is a hole in the airbox somehow that is letting dust get in but from what I hear this is a huge issue with these machines anyway because of the horrible location of the stock air intake. I know lots of people who have added snorkels with pre filters to help with this.
Screenshot 20230409 091536 Amazon Shopping 20210606 150450
Reactions: JayPo
DRZRon1
DRZRon1
852
2,744
Interesting green spot - looks unoiled ?
I’m frugal as s***, I wash those kinda filters with dawn in a bucket and air dry - whatever motor oil is laying around and a ziploc for oiling…
u have pic of the dirt past the filter ?
JayPo
JayPo
Somewhat Well-Known Member
10,594
103,037
Tennessee
View attachment 382663 View attachment 382664
You can check for a hole/leak in the air intake system be letting the engine idle and covering the air intake (I use my hand to block the air intake on my Yamaha). If using your hand you can feel the suction if the air intake plumbing is tight. The engine should sputter and eventually stop running if there are no leaks. If there is a small leak you may be able to hear a hissing sound to help locate the leak.
