P500 P500 Inferno heater instal- lessons learned?
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
I finally decided I’m finished freezing when plowing or hunting here in Montana. I have an Inferno heater on order from Side By Side Stuff.
I’m sure the instal instructions make sense, but has anybody installed one and wished they’d known something they learned installing it- before they did?
Second, it looks like the cold air intake is vented to the outside. Is it possible to run a duct from the cab so heated air is reheated, etc to help it get the cab warmer with all the places it can leak around the doors, etc.
BTW- SxS Suff has the P500/520 Falcon Ridge soft doors on sale for $139 regularly $465.
Thanks!
158,639
Thanks!
I just ordered a set of those doors. They want like an extra $100 for zippered windows but it looks like they come zippered anyway so you can get the door open. I only plan on running them in the winter and for $150 I'm not expecting them to seal very well. Thanks BHB.
futzin
futzin
3,245
23,369
Kentucky
Now, you're finished with it! :p
Scoop
Scoop
4,241
15,885
  3. Talon R LV
Not a 500/520, but I installed an Ice Crusher heater in my P1K5. The air intake for that is on the inside of the cab (under the dash pointing down). If you can figure out a way to route your intake to pull air in from the cab, I think that would be a much gooder idea.
Gooder
MarlinWalker
MarlinWalker
57
170
This guy did the very thing you are looking for. He used a 3d printer to make the routing. I have always wanted to do that with my system but never got around to it. Maybe it would be an excuse to buy a 3d printer??
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Good information, thanks. The Inferno arrived today UPS so it’s time to get serious.
The_Frontiersmn
15
23
Minnesota
Once temperatures get below freezing you're going to want to unplug the radiator fan and cover the radiator. It will make a massive difference in heat output.
Reactions: MarlinWalker
DRZRon1
DRZRon1
865
2,806
Thanks!
good luck - stare at it a while, re-stare, drink a beer or two - then plow into mounting the heater core, if ya want to recicr air, I am sure between stove pipe, pvc, etc you can come up with an adapter to get the flex hose on the intake to recicr the warm air.....
john790
330
1,015
Clinton ohio 44216
If you pull your air from outside the cab your cab will be postive.That means all your cab leaks will try to push cold air out.This works real well at low speeds only.
Reactions: Buckaroo41
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
That’s a really good point. I think if I seal that opening in the lower doors with pieces the foam insulation sheets used on foundations, and find some thick rubber moulding for the bottom it may would help. I’ll start a new thread on the topic.
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Thanks. All the more reason to install an inexpensive ‘analog’ water temp gauge next to the switch when I install it.
When the temps get really cold here, I’m primarily using the P5 for plowing.
The_Frontiersmn
15
23
Minnesota
I haven't had any issues just using the OEM digital temp gauge. As long as it's below freezing the heater seems to be a sufficient radiator by itself. I only overheated once last winter, and that was a warmer day where the snow was so sticky that it built up on the engine to the point that it overinsulated it. Also, if you have the stock gauge set to a setting other than temp, it will automatically switch to temp as soon as your engine gets too hot.
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Thanks good to know
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Started installing today. Instructions are straight forward. I stopped at moving the radiator hoses because I remembered reading here to only use Honda Blue antifreeze.
I found a small wood carving chisel worked well trimming the plastic after drilling a bunch of holes to create the openings for the defrost vents and switch. I rocked it hole to hole to cut, then shaved the opening to final size.
8683db2efa2522e4c97911cb7be1d386
The 2 ‘extra’ things I did was use metal hi temp duct tape to secure the flexible hose in addition to zip ties and taped the hose away from the steering linkage to avoid it wearing a hole with time.
456fc2c3ac843c143430e1a23b3ea81c
D9be94c452bcb80e4eb1a79f9b637cf7
To be continued.
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Finished it up. Instead of using the 90 degree pex connector and 2 lenghts of hose as in the instructions, I found a heater hose with a 90 degree bend at the local auto parts store. Eliminates 2 potential leaking connections and is neater.
Driving up and down our road to eliminate any air in the coolant system…. It pumps out heat!
9d38d0bc3533c503ec68a1d7e16525b2
LandofCheese
LandofCheese
44
416
Do you have a part number or size or anything for that 90 degree hose? I'm looking to install this heater soon as I've had it in the garage since last winter and love the idea of an easy less potential leaky solution.
DRZRon1
DRZRon1
865
2,806
Napa, Amazon, summit, all that is ex to get - jeez, double hose clamps!!!!
