P500 P500 won’t fire
A
Andrewwray88
10
7
Jacksonville
Hi guys new to the group! My 2017 pioneer 500 won’t fire, no fuel pump and no dash. Put in new fuses, and relays. Tried different battery, different cpu, different ignition switch, cleaned connectors, checked the grounds and I have power going to the pcm. Would appreciate some input! Thanks
TxDoc
TxDoc
1,657
5,736
TEXAS 🇨🇱
photos.app.goo.gl
Welcome to the Honda dimension.
Lotta nice and helpful people.
Someone with 500 expertise will come in, stand by.
JollyJoker
JollyJoker
91
191
Minnesota
Did you clean up the grounds that are clustered together on the frame below and to the right of the battery box?
Reactions: 906UP
906UP
906UP
13,123
122,568
da Yoop
Do you have a 12v test light or a volt meter? Start at the battery and work your way out. See if you have voltage at the battery, then from the battery + to the frame, next check the "feed" side of the 40 amp main fuse. In the diagram below a solid red wire goes from the battery + to the main fuse and a red & white striped wire (R&W) from the main fuse feeds everything else. Start with that and report back.
P5
A
Andrewwray88
10
7
Jacksonville
Yes I started with those and haven’t found anything.
906UP
906UP
13,123
122,568
da Yoop
Do you have power at the 30a ES, 10a Pump & 15a Fan fuses? These should have power all the time.
I misread the 1st post and see you have power at the ECM.......at what pin #?
Reactions: TxDoc
A
Andrewwray88
10
7
Jacksonville
Red yellow not sure pin #
Reactions: TxDoc
906UP
906UP
13,123
122,568
da Yoop
I sent you a PM with a wiring diagram, check for power with the key on at the red/green wire on the speedo/display, if you have power the problem is a ground (negative) issue, if you don't have power you have a relay, connection to the relays or a broken wire somewhere in between.
906UP
906UP
13,123
122,568
da Yoop
That would be pin B-1, that means you also have power at the fuse box. When you turn the key on see if you have power at the Fan & Acc fuses.
Reactions: TxDoc
