P500 Philips head screws under seat
dougbo44
19
58
South Jersey
Can anyone offer suggestions on removal. Mine are installed so tight head is stripping and screw not coming loose....thanks in advance!
320,749
Maybe cut slot in screw and use regular screwdriver.
Reactions: Buggyman
Red500
Red500
5,359
58,146
Greeneville, Tn.
I used what the boss man suggest. What's a jis/plus screwdriver
Reactions: Buggyman
Neohio
Neohio
Beast of the East
13,477
66,500
Painesville Ohio
1658497444479
Reactions: Buggyman and futzin
Peter_72
Peter_72
792
6,526
Louisiana
I used a dermal to put flat sides on them then used vise gripes
Reactions: Buggyman
lee
lee
Village Idiot
2,350
13,232
Springfield Ohio
Not that it matters, but it's my contention the issue is not the factory over tightening the screw.
I think the issue is the fastener or the threads in the frame are corroding a little and causing the screw to be stuck.
The solution is to buy a KRX.
Not really, smack the screw with a hammer to break it free.
I use a small punch (not usually effective) or one of those cheap interchangeable blades on a single screw driver handle things (I think it was a gift from my mom).
Drop the plus driver in to the screw, smack the other end with a hammer.
However, the thing that @Hondasxs suggested also works.
Impact driver is my last chance before I break out the gas axe (cutting torch).
When you reinstall any screws apply anti seize to the treads. (this step relates to my corrosion theory above)
MI-Trailblazer
MI-Trailblazer
262
1,234
Parma, MI
I've used the screw driver hex bits that go in your inter-changeable driver or cordless impact driver- stuck in one of the sockets that Torx bits are usually in, then a ratchet and put all my weight on the head of the ratchet and leverage of the handle to break those phillip's loose.
Reactions: Buggyman
Neohio
Neohio
Beast of the East
13,477
66,500
Painesville Ohio
A handheld impact driver is your best friend for these screws in question.
The screwdriver I linked previously is an impact driver. Whack the end with a hammer and it will shock it loose.
I am not familar with the unit @Hondasxs posted on whether it comes with Phillips or JIS bits.
I know for a fact this Vessel comes with the proper JIS bits.
K
KPM
41
124
Prairieville LA
I took a dremel and made a big slot cut them took a big flathead screwdriver and some kroil and got mine out. All of mine were thought but one required the dremel.
Reactions: Buggyman
Neohio
Neohio
Beast of the East
13,477
66,500
Painesville Ohio
Here is a thread of some basic and nice to have tools for working on the 1000. A lot of the basics cross over to other platforms as well.
Reactions: Buggyman
267,227
A good friend of mine (John Doe #2) sed he has seen that HODOR now installs those screws with green sleeve retainer lock-tite since the conclusion of Game of Thrones series. Rumor has it The Hound then QC double checks for proper tightness of 157ft lbs by using only his thumb and index fingers.
160,066
Somebody's been watching the marathon on HBO... me too.
lee
lee
Village Idiot
2,350
13,232
Springfield Ohio
So rumor has it, the QC guy puts a torque wrench on the fastener and feels for a click.
Paint mark the screw and kick it down the line.
Wheather the screw turns or not has no bearing on its ability to be paint marked.
(But I still think the plus slots would be stripped out if they where tightened that much on the line)
Reactions: futzin and Buggyman
267,227
Hodor, torque that bolt and paint it.
Reactions: Buggyman
Chevyfan396
Chevyfan396
25
141
Palouse, Wa
I used a regular 18v makita impact driver and they came right out. Could not budge them with a regular screw driver even with a good hold.
Reactions: Buggyman and CID
